hi im new here..im also new to these Converting things..
i have videos i want to convert
i got the TMPGEnc Latest Version
i tried looking for the help file...but its not there
so i have VCDHELP.com Forum to fall back on....
I need help on using this Program
First ,i clean my .AVI file from errors such as frames that will stop that can cause lip-sync....and then i used "FX MPEG WRITER" to convert it to Video Bitrate of "1150 kbps,29.97 frames per second,and the frame "352x240 " and of course its in "NTSC"
And then finally,trying to burn it with ROxio VCD Creator,i got an error message saying "System Clock Reference",with a large red "X",i cant do anything,but i searched this forum and found this thread,about sumone wh ohas this trouble as mine,the mod replied saying using TMPGEnc to multiplex my video file and problem solved,but the prob is,i dunno how to use TMPGEnc,i need help,step by step..
help will be appriciated
Aaliyah Is One In A Million,
She Sings On And On And On
She Gives Me A Really Good Feeling,
All Day long.......
Aaliyah Dana Hauhgton
- REST IN PEACE -
1979 - 2001 -
I dunno about Roxio but is the mpeg file so big that it would fit on the cd youre trying to burn it without problems? If the size is ok try Nero I use it without problems.
And with TMPG use wizard it helps.
And by the way you dont need to use any divx fix if youre avi is ok!
By the way if you need step by step help then simply go to http://www.vcdhelp.com/convert
and click on How to convert toVCD with TMPGEnc and of course dont forget about the codecses you will need mentioned there.
To multiplex with TMPGEnc start the program up, then in the top left corner select the following
File --> MPEG Tools
this will take you to where you need to go to multiplex, there are four tabs, you want to use Simple Multiplex, click on the Browse buttons to select the Video and Audio files for it to put together, TMPGEnc will automatically select the correct option from the little drop down menu so dont worry about that
then when the two files are selected, Click the Browse button next to Output (The third box down from the top) and enter the name of what you want the finished file to be called and select where you want it to go.
Finally press Run and it will work its magic
Hope this helps, it can get confusing but help is here
ciao
TLTwThe Hellsing family will purify this world... -
And another one blown away by Roxio. Do yourself a favor and dump it.
The following tools I find indespensible:
VirtualDub (freeware)
DVD2AVI (freeware)
VFAPI Reader Codec Reader (freeware)
avisynth (freeware)
bbMPEG (freeware)
VCDEasy (freeware)
Nero Burning Rom (shareware, 30 day trial, $49 U.S. for online purchase)
and last but not least TMPGEnc Plus (15 day trial, $49.95 online purchase and a bargain if you ask me).
This may seem like a lot of tools to master, but if you do your homework and read thru the how-to guides you'll see how each of these complements the other and your results will speak for themselves.Warning! I'm baaaaaaaaack
Runaway PF usage
By JudgeGarth in forum ComputerReplies: 7Last Post: 1st Feb 2009, 18:35 -
100% CPU Usage while outputing from TMPGEnc DVD Author
By lj01 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2008, 11:09 -
internet usage
By d_unbeliever in forum ComputerReplies: 10Last Post: 17th Apr 2008, 11:54 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 10:59 -
Usage of DirectDvd ???
By hulinning in forum Software PlayingReplies: 1Last Post: 28th Nov 2007, 10:51
