Ok, I've beemn encoding for awhile an for some reason when i downloaded a filter for xvid playback my THPGEnc has went crazy.Now it wil not accept any of my avi's it seemed to work fine before i fooled with tring to use that filter an from what i can seen i uninstalled it.Any help would be nice,THANKS
Results 1 to 11 of 11
Which version of TMPGEnc are you using ?
I Suggest you try downloading and using the latest 2.59Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I've got that one i think it's that filter for some reason. i think it was called ffdsshow or something like that. when i try to load tmpgenc it loads slow an it wont load the avi's at all an i did a virus scan.have any suggestions?
If you've recently installed other software for DVD copying it may cause problems. The only way around this I have found is to uninstall all the related software and re-install it from scratch. I recently had problems with both TMPGEnc and DVD2AVI which were cured by a fresh re-installation.
Oh dear, yeah, i'm familiar with ffdsshow, the crappiest codec pack i've seen
Was supposed to be replacing all other codecs, nothing but trouble, make it
absolutly sure you uninstalled it, and all it's files are no longer on your PC!
I'd strongly suggest you Install Kristal Studio Pack and then DivX5Pro again!
That should fix your problem.Email me for faster replies!
Best Regards,
Sefy Levy,
Glad To Be Of Help! 8)
Let me know if you are still having problems!Email me for faster replies!
Best Regards,
Sefy Levy,
Best Regards,
Sefy Levy,
Best Regards,
Sefy Levy,
Black Bar problems with TMPGEnc
By ereiamjh in forum Video ConversionReplies: 5Last Post: 22nd Mar 2010, 10:32 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
