I had a Divx file with AC3, 5 channel audio that I wanted to convert to VCD. My normal method with this would be to save a wav file using direct stream copy in vdub, then rename it to ac3 and run it through headac3he creating a wave file for use in TMPGEnc. Anyway headac3he, was having none of it, giving an arror along the lines of "sync error, the ac3 file may be corrupt".
I opened the video in TMPGEnc no problem but it would not recognize the audio, so i increased the direct show multimedia file reader from -1 to 1, it would now recognize the audio no problem. I encoded it expecting the audio to be out of sync, but no, it is perfect. So if you are having problems with 5 channel ac3 audio, this may be a solution.
I will add that so far I have only tried this on 2 files.
It also works for me, but not on all videos with ac3s. Maybe the ones that are in vbr audio...
http://www.vcdhelp.com/tmpgenc.htm#problems (convert divx with ac3)
(craigtucker: All divx to conversions should be in the newbie conversion forum.) -
Sorry, I really should know better
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
Convert MKV with ACC audio to AC3 audio for PS3 playback
By wolvie77 in forum Video ConversionReplies: 4Last Post: 25th May 2010, 10:13 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
Convert divx avi with dts to ac3
By mk15 in forum AudioReplies: 3Last Post: 23rd Jun 2009, 03:46 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22
