  1. Acually it's more of a question, but when I preview there is a quick jump in the audio when going from one chapter to the next, i'm wondering if that will be on my final VCD product.
    Thanks for your help.
    USA
    I have M2 Edit Pro 5.0 and find it very difficult to use so I switch to My Flix XE 1.0 for VCD editing(trimming) and I like the program so much.
    My Flix XE 1.0 is from the same company that created M2 EDIT but much easier to use but it can only do good VCD editing and not SVCD.
  3. That sounds good and all but i'm still wondering how the final product will be.
    Just cutting one large video into a good amount of chapters, but wanted them to play fine (no skips, jumps or pauses between chapters). I was wondering if this is possible at all (I know DVD's do it fine, but i'm very new to VCD's)
    Thanks for your reply >^_^<
    USA
    So you want to have multiple chapters(many video clips) burned on a cd as VCD and then when you play back the VCD there should be no pause or skip etc ? Is that right ?
    If so you can just select a bunch of video clips and burn them as VCD with nero but select the pause time as 0 seconds to eliminate the gap between video clips.
