I use a Pinnacle DC-10 capture card. It captures in MJPEG. I set up a network in my house and now I'm trying to open my MJPEG .avi files on a computer which doesn't have my capture card on it. So it yells at me since I don't have the codecs. I try to open in virtual dub and it kind of works.
I get this wierd thing where only half the lines show up. Looks like this:
http://adamrulz.com/sailormoon/images/lines.jpg
Here's a close up look so you can see that every second line is just black:
http://adamrulz.com/sailormoon/images/biglines.jpg
Another wierd thing if I shuttle around in vdub it sometimes pics up a frame which will stay where the black lines where and I'll get this wierd double exposure like this:
http://adamrulz.com/sailormoon/images/double.jpg
So what's the deal? Is this a virtual dub problem or a missing codec problem?
I get that I don't have the MJPEG codec on this comp. So I tried doing a full install of the software that came with my DC-10. Didn't do a damned thing. I guess the codec's in hardware? Does that make sense?
I know there the MJPEG codec by PicVideo but there's just no way I'm paying 30$ just to get something I should already have. Especially since I don't even know if this is my problem. So... is there a way to get this codec off my other computer or something?
I had a similar problem. VirtualDub does have inbuilt MJPEG support but it doesn't appear to be perfect. ( Might pay to try the newest release.
) The best option is to grab one of the other MJPEG codecs such as Picvideo and install that on the other machine. That should resolve the problem.
Good Luck,
Ian -
The newest vdub didn't work. I downloaded the trial picvideo codec which worked but... well it did have that logo. At least I know there's a solution so I'll just keep looking. Thanks.
Trouble with opening flv files in Virtual Dub.
By drumwork83 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2012, 21:53 -
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49
