On my DVD remote i have a joystick that helps select chapters and menus. When i create a menu using NERO, it does not work. I have to use the numbers at the bottom. Is this supposed to be like this? I would really like to use the joystick (easier). Is there any way to do that?
"With great power comes great responsibility"
WHO AM I? - I'm SPIDERMAN-(for real)
Guest
There is a way, you have to program it by yourself in the XML file. However, this thing is EXTREMELY RARELY supported... It's mostly available only in CD-I players, and maybe also VCD-2.0 players, but haven't heard of any DVD player that supports this VCD feature.
Further more, the information of what colors to use in highlights and what color the cursor will be is saved in the CD-I setup files which no DVD player reads...
mpegobsession
Menus & Chapters Multiavchd
By funkyirishman in forum Authoring (Blu-ray)Replies: 4Last Post: 30th Dec 2011, 11:08 -
Help with what software is good for menus and chapters
By shashgo in forum Authoring (DVD)Replies: 9Last Post: 3rd Jan 2009, 17:09 -
Which soft. to adjust a pic. to a vid. in realtime manually even w\joystick
By Nicholas76 in forum EditingReplies: 0Last Post: 29th Oct 2007, 05:50 -
Episodes from Several DVD's Onto One With Menus and Chapters
By Savutay in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2007, 15:41 -
Control wheel joystick for spinning through video
By deanbrown3d in forum ComputerReplies: 4Last Post: 28th Sep 2007, 01:05
