I have no trouble if I connect with the (expensive) sound out anologue cable from Apple, however I can not make a connection with my firewire cable, I have all the extensions, I think. Has anybody had the same problem??
Captjo.![]()
Hi captjo,
I have the same prob.
Using iBook 500mz+OSX10.2.
Tried exporting from iMovie, nothing nada! -
Hi Noodle Stroodle.
I think I am on the right track, from Imovie you export to camera and quicktime also has an export via firewire, an extra program is needed for that, I am tracking it down.
Captjo -
Hiya Captjo,
Finally figured it out!
In iMovie export your film to camera, having already connected your FireWire cable, set the 890 to cam2 input, hit export then record, easy!
Firewire Connection - how to secure??
By motown01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Nov 2009, 14:39 -
sony camcorder firewire connection
By rizvii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th May 2009, 00:23 -
What is the difference in connection of DV and pc between USB and FireWire?
By coody in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2008, 15:17 -
firewire connection without sound
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Apr 2008, 09:10 -
Testing Camcorder Firewire Connection
By wacole in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Nov 2007, 11:41
