Okay, I'm taking some DV videos that I have and putting them on DVD for my friend who lives in Spain. Obviously they are in NTSC format but I need to convert them to PAL. I already sent him one in NTSC format and he can watch it but it's in black and white. He says there's no way to set his TV to accept an NTSC signal. So now I have to go about converting to PAL. What should all my settings be in TMPGENC? How do I set it to preserve the aspect ratio? Do I need to set it to de-interlace since it's DV? I think I have a basic grasp of all of this but I'm still learning and some of the settings are confusing.
Thanks so much!
-Andrew
I have the same prob myself....
I have some NTSC VHS tapes and I want to convert them to PAL
I search the forum and I found many interesting suggestions.
I'll test them tonight (the VHS tapes just arrived)
Just for the story:
Some users suggest to grabb with Virtualdub the NTSC tape as PAL and encode the avi to mpeg. Anorthodox way, which I need to test myself to believe it!
The most advance technique, is grabb the VHS as NTSC, then encode it to a very high bitrate mpeg 2 and then re-encode it to less high mpeg 2 PAL following this guide: http://www.vcdhelp.com/forum/userguides/78178.php
There are also some framerate techniques, including inverse telecine the source to NTSC 23.97 and then slighty boost it to 25fps to make it PAL.
I shall learn many things for this in the next 3 weeks!
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
