The problem I have may be specific to the Philips DVD724AT or maybe others have found this with other DVD players as well.
I thought the problem might be encoding so I started the following post. Now I am beginning to think the problem is the DVD player so I posted here. To try to avoid double answeres I amd crossreferencing these two posts.
http://www.vcdhelp.com/forum/viewtopic.php?t=128618
The philips unit when I have the sound set for SPDIF RAW(digital stream) all DVD's and audio CD's autodetect and play perfectly as DD5.1 or PCM as the case may be no problems. When I run any Audio CD that I have made (even from DD5.1 sountracks) the Philips works fine and my stereo auto detects the sound track as PCM and plays fine. Problem:[b] If i put in any VCD, SVCD or CVD with any sound encoding selection in TMPGEnc (stereo/Joint Stereo/ Dual Channel and have the SPDIF on the Philips set to RAW the Philips does not pass any sound to my stereo. To get sound I have to set it to PCM and then it works.
I hooked up my original Toshiba SD1200 (replaceing this one with the Philips) I have the Audio set to BITSTREAM and everything works correctly including with the VCD. I do not have to set this unit to PCM. Has anyone seen this problem with any other units or if you have the philips724AT does your do the same thing.
Results 1 to 1 of 1
AVI container encoded with H.264/AVC video and PCM sound
By LoLaha in forum Video ConversionReplies: 6Last Post: 20th Mar 2012, 23:14 -
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 05:27 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
Audio options in DVD player, RAW or PCM?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2009, 06:00 -
no sound after switching from pcm to dolby with power2go..PLEASE HELP
By kingofdabay122 in forum Newbie / General discussionsReplies: 5Last Post: 4th Jul 2009, 10:41
