If my DV camera does not support analog input, is there something that I can add to the camera that will make it that way??? I really need to transfer VHS tapes to the computer and burn them to DVD without having dropped frames.....
No. Sorry. You can get an external box as a passthru, but it runs a couple hundred bucks. If you can return the cam, it might be worth it to look at spending that extra for a cam that has the feature. Or, you could just get a PCI card that can do your capping in real time, like a Hauppauge PVR250, which should be less $$.
If you want no frame drops, get the Pinnacle DV500 DVD. I just got one last week and I've been pretty happy with it except I can no longer hibernate the system. Hopefully they will have a fix out some time soon. I was dubbing onto my DV cam, but VHS tapes are 120min where my DV tapes were 90min. The DV500 is fast and has hardware accelerated MPEG-2 encoding that looks really good. It takes about 6min to render DVD quality video on a 5min clip.
This is the cheepest I found it for, and it had $2 second day shipping. Also, there is a rebate for a $109 Contour Shuttle.
http://www.googlegear.com/jsp/ProductDetail.jsp?ProductCode=323007 -
If you are after an AtoD converter, I have heard good things about the canopus ADVC-100
Take a look at www.dv-in-france.com, maybe your DV-camera does support analog-in and it's just blocked. My camera (sony trv6e) didn't have DV-in, and with a simple cable and some codes I can put my edited video back to the camera
Just because you aren't paranoid, doesn't mean they aren't out to get you! -
Thank god for the altavista translator. LOL My Sony PC100 isn't listed, but they havn't updated that site for a long time. I did this kind of thing for my stand a lone sony dvd player to get rid of macrovision and blocking you from fast forwarding through the FBI warnings. Worked great.
analog upconverting
By jaybird in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2010, 21:20 -
Analog tapes to PC
By stellabelch in forum Capturing and VCRReplies: 8Last Post: 23rd Oct 2009, 11:57 -
Portable PAL analog (yes, analog!) television set
By stuey123usa in forum Capturing and VCRReplies: 0Last Post: 22nd Jun 2009, 19:23 -
Analog vs Digital TV
By J. Baker in forum Newbie / General discussionsReplies: 9Last Post: 10th Jan 2009, 03:21 -
Analog to DV Tape vs. Analog directly to computer
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 7th Sep 2008, 09:45
