Results 1 to 21 of 21
  1. I used DVD2SVCD to copy Beauty and the Beast DVD BUT when it was done it made the 1st CUE file 830Mbits so when i tried to burn it using NERO i got a message saying the DISC was too small. Do i need to change the setting in " BITRATE " to 740 instead of 800 ? Or should i manually enter a slightly smaller number like 780?? Or is this a NERO problem...?? Thanks for all replies....
    Jul 2002
    Salem, OR
    Are you using 80 minute blanks? If the actual byte count (not what Exporer reports) of an MPG files is roughly 830mbs it will fit on an 80 min. CD. For BIN/CUE's, I think the number is actually slightly higher. You might also want to check to see if you have Nero configured to allow overburning.
  3. Are you burning the Bin file to disk in data form or are you Burning a CD Image ?
    The Hellsing family will purify this world...
  4. Originally Posted by TheLostTimberwolf
    Im using the " BURN IMAGE " function.
    Are you using 80 minute blanks? If the actual byte count (not what Exporer reports) of an MPG files is roughly 830mbs it will fit on an 80 min. CD. For BIN/CUE's, I think the number is actually slightly higher. You might also want to check to see if you have Nero configured to allow overburning.?
    YES, im using 80 Min blanks. I believe the size in EXPLORER was 832Mb. Next time i'll write down the EXACT size. I DO have overburning checked. BTW this has happened MORE then once. So should i change the size under BITRATE to <800 like 780 OR use the default of 740.
    Jul 2002
    Salem, OR
    Where are you seeing "BITRATE"? All you should have to do is select the CUE file and tell it to burn. Uh...you're not using Nero Express are you?
  6. Originally Posted by mdm
    I"m talking about the BITRATE setting under DVD2SVCD
    Jul 2002
    Salem, OR
    Hmm...I'm not sure what that setting is for (I know what a "bitrate" setting is, but it usually doesn't refer to the size of your disc image). If DVD2SVCD is using this setting to set the disc image size, then yes, lower it a bit.
  8. ok give this a shot
    open DVD2SVCD and in the CD Image tabe click on, Dont Make image.
    in the bitrate tab make sure the CD Size is 800 if you are using 80 min cd's. Also make sure that the total amount of time is correct, if the movie goes for 1 hour and 30 mins thats 90 min total, so in the bitrate tab, find the range say '75 and 110' ,a 90 min movie falls into this range, and then make sure that is the one you set for 800.
    then using nero, burn a SVCD.
    Are you making chapters? is that why you use the CD Image option?
  9. Originally Posted by TheLostTimberwolf
    ok give this a shot
    YES I'm making chapter in it so i can skip ahead to different parts of the movie if i want. Under the " Bitrate " tab here's what is set:
    Between 0 and 50 - use 1 CD size 740
    Between 50 and 76 - use 1 CD size 800
    Between 75 and 100 - use 2 CD size 740
    Between 100 and 125 - use 2 CD size 800
    Is this right.? Here's a copy of the log file that made the SECOND disk too big..... THANKS FOR ALL the replies.
    - 12/13/2002 9:00:15 PM
    - DVD to SVCD Conversion
    - DVD2SVCD ver. 1.0.9 build 3
    Initializing
    Initializing finished.
    - 12/13/2002 9:00:17 PM
    - Analyzing subtitles
    Subtitle found: StreamID: 0x22 Language: Espaņol
    Subtitle found: StreamID: 0x23 Language: Espaņol
    Subtitle found: StreamID: 0x26 Language: Espaņol
    Subtitle found: StreamID: 0x27 Language: Espaņol
    Subtitle found: StreamID: 0x20 Language: English
    Subtitle found: StreamID: 0x21 Language: English
    Executing subtitle selection/verification.
    Subtitle selection/verification accepted.
    1 subtitle streams selected.
    Saving Subtitles ini file
    - 12/13/2002 9:00:52 PM
    - DVD2AVI
    Creating DVD2AVI INI file:
    - C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
    Variable settings:
    iDCT_Algorithm: 32-bit SSE MMX
    Executing DVD2AVI.
    Executing DVD2AVI. Commandline:
    "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[F:\DVD RIP\unbreakable\DVD2AVI_Project_file] -IF=[C:\DVD RIP\UNBREAKABLE\vts_01_1.vob,C:\DVD RIP\UNBREAKABLE\vts_01_2.vob,C:\DVD RIP\UNBREAKABLE\vts_01_3.vob,C:\DVD RIP\UNBREAKABLE\vts_01_4.vob,C:\DVD RIP\UNBREAKABLE\vts_01_5.vob,C:\DVD RIP\UNBREAKABLE\vts_01_6.vob,C:\DVD RIP\UNBREAKABLE\vts_01_7.vob]
    Analyzing DVD2AVI Project file
    Force Film activated!
    Framerate: 23976
    DVD2AVI processing done.
    - 12/13/2002 9:04:49 PM
    - Free on drive F: 10290.27 mb
    - Extracting the subtitles.
    Subtitle extraction finished. Extracted these subtitles:
    SVCD Stream no: 1 Language: English Num. of subs: 1312
    - 12/13/2002 9:10:41 PM
    - Free on drive F: 10269.53 mb
    - AUDIO Extraction
    Found AC3 stream id: 0x80
    Filename: F:\DVD RIP\unbreakable\Extracted_audio_1.ac3
    Audio1 delay: -84 ms
    Audio extraction finished.
    - 12/13/2002 9:15:16 PM
    - Free on drive F: 9927.69 mb
    - AUDIO conversion
    Converting Audio to MP2. Filename: F:\DVD RIP\unbreakable\Extracted_audio_1.ac3
    Executing BeSweet. Commandline:
    "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "F:\DVD RIP\unbreakable\Extracted_audio_1.ac3" -output "F:\DVDRIP~1\UNBREA~1\Encoded_audio_1.mp2" -logfile "F:\DVDRIP~1\UNBREA~1\Encoded_audio_1.log" ) -azid( -L -3db -c normal -g max ) -ota( -d -84 ) -2lame( -e -b 128 -m s )
    Audio conversion of F:\DVD RIP\unbreakable\Extracted_audio_1.ac3 finished.
    Audio conversion finished.
    - 12/13/2002 9:28:08 PM
    - Free on drive F: 9829.98 mb
    - Converting Pictures
    Converting: C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp
    Finished converting pictures
    - 12/13/2002 9:28:14 PM
    - Free on drive F: 9829.17 mb
    - Video Encoding using Cinema Craft
    Executing Cinema Craft Encoder.
    StreamSectors: 1666479976
    AudioSectors: 103829348
    VideoPAPO: 24206292
    ScanOffsetBytes: 184157
    SeqAligningBytes: 11704188
    DVDBytes: 0
    VideoEndHeader: 8
    SubtitleSectors: 4606168
    EmptySectors: 238.00
    PictureSectors: 300.00
    PureMPEGStream: 1521949815.47
    Seconds: 6402.73
    CalcMPEGStream: 1521949815.47
    Frames: 153464
    CDSize: 800.00
    Cut point 792.00
    Variable Settings:
    Frames: 153464
    Anti Noise Filter: Off
    Passes: 4
    Image Quality: 17
    VAF file creation: On
    Video Encoding Mode: CBR
    Avg. Bitrate: 1901
    Aspect Ratio: 16:9 (borders added, encoded as 4:3)
    ---AVS Begin---
    LoadPlugin("C:\PROGRA~1\DVD2SVCD\SIMPLE~1\SIMPLE~1 .DLL")
    LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\MPEG2DEC .dll")
    mpeg2source("F:\DVDRIP~1\UNBREA~1\DVD2AV~1.D2V")
    SimpleResize(480,360)
    AddBorders(0,60,0,60)
    ResampleAudio(44100)
    ----AVS End----
    Closing program
    CCE Max Speed: 1.790
    Video Encoding finished.
    - 12/13/2002 10:29:24 PM
    - Free on drive F: 8341.14 mb
    - Video Pulldown
    Executing Pulldown. Commandline:
    "C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "F:\DVD RIP\unbreakable\Encoded_Video_CCE_NTSC.mpv" "F:\DVD RIP\unbreakable\Pulldown_Encoded_Video_NTSC.mpv"
    Video pulldown finished.
    - 12/13/2002 10:33:42 PM
    - Free on drive F: 6890.77 mb
    - Converting Pictures from ES to PS
    Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini
    - 12/13/2002 10:33:44 PM
    Executing RunbbMPEG. Commandline:
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\unbreakable\ChangeCDPicture.bmp.mpg"
    - 12/13/2002 10:33:47 PM
    - Free on drive F: 6890.70 mb
    - Multiplexing and cutting
    Offset in Seconds: 5
    Executing bbMPEG.
    Variable Settings:
    Movie offset: 5 seconds
    Cut point: 792 mb
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\unbreakable\bbMPEG_Muxed_File.mpg"
    Multiplexing and cutting finished.
    - 12/13/2002 10:41:25 PM
    - Free on drive F: 5311.78 mb
    - Determining length of audio
    - 12/14/2002 4:33:52 AM
    Initializing
    - 12/14/2002 4:33:56 AM
    - Free on drive F: 5311.80 mb
    - Crash Recovery
    - Restarting from: SVCD Authoring
    - 12/14/2002 4:33:57 AM
    - 12/14/2002 6:14:43 PM
    Initializing
    Invalid filename
    - 12/14/2002 6:16:11 PM
    Initializing
    - 12/14/2002 6:16:13 PM
    Subtitle found: StreamID: 0x21 Language: Espaņol
    - 12/14/2002 6:16:35 PM
    - DVD2AVI
    Variable settings:
    Executing DVD2AVI.
    "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[F:\DVD RIP\reign of fire\DVD2AVI_Project_file] -IF=[C:\DVD RIP\REIGN_OF_FIRE\vts_01_1.vob,C:\DVD RIP\REIGN_OF_FIRE\vts_01_2.vob,C:\DVD RIP\REIGN_OF_FIRE\vts_01_3.vob,C:\DVD RIP\REIGN_OF_FIRE\vts_01_4.vob,C:\DVD RIP\REIGN_OF_FIRE\vts_01_5.vob,C:\DVD RIP\REIGN_OF_FIRE\vts_01_6.vob]
    Framerate: 23976
    - 12/14/2002 6:19:58 PM
    - Free on drive F: 7782.83 mb
    SVCD Stream no: 1 Language: English Num. of subs: 1478
    - 12/14/2002 6:25:24 PM
    - Free on drive F: 7758.44 mb
    - AUDIO Extraction
    Filename: F:\DVD RIP\reign of fire\Extracted_audio_1.ac3
    Audio1 delay: 0 ms
    - 12/14/2002 6:29:44 PM
    - Free on drive F: 7431.75 mb
    - AUDIO conversion
    Converting Audio to MP2. Filename: F:\DVD RIP\reign of fire\Extracted_audio_1.ac3
    "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "F:\DVD RIP\reign of fire\Extracted_audio_1.ac3" -output "F:\DVDRIP~1\REIGNO~1\Encoded_audio_1.mp2" -logfile "F:\DVDRIP~1\REIGNO~1\Encoded_audio_1.log" ) -azid( -L -3db -c normal -g max ) -2lame( -e -b 128 -m s )
    Audio conversion of F:\DVD RIP\reign of fire\Extracted_audio_1.ac3 finished.
    - 12/14/2002 6:42:02 PM
    - Free on drive F: 7338.38 mb
    - 12/14/2002 6:42:09 PM
    - Free on drive F: 7337.56 mb
    AudioSectors: 99225504
    VideoPAPO: 24277608
    ScanOffsetBytes: 175986
    SeqAligningBytes: 11184888
    DVDBytes: 0
    VideoEndHeader: 8
    SubtitleSectors: 5889016
    PureMPEGStream: 1525726966.00
    Seconds: 6118.74
    CalcMPEGStream: 1525726966.00
    Frames: 146655
    CDSize: 800.00
    Cut point 791.00
    Variable Settings:
    Frames: 146655
    Passes: 4
    Image Quality: 17
    Video Encoding Mode: Multipass VBR
    Min. bitrate: 300
    Max. bitrate: 2530
    Avg. Bitrate: 1994
    ---AVS Begin---
    mpeg2source("F:\DVDRIP~1\REIGNO~1\DVD2AV~1.D2V")
    ----AVS End----
    Closing program
    CCE Max Speed: 1.680
    - 12/14/2002 11:51:35 PM
    - Free on drive F: 15965.50 mb
    - Video Pulldown
    "C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "F:\DVD RIP\reign of fire\Encoded_Video_CCE_NTSC.mpv" "F:\DVD RIP\reign of fire\Pulldown_Encoded_Video_NTSC.mpv"
    - 12/14/2002 11:56:02 PM
    - Free on drive F: 14511.89 mb
    - 12/14/2002 11:56:05 PM
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\reign of fire\ChangeCDPicture.bmp.mpg"
    - 12/14/2002 11:56:09 PM
    - Free on drive F: 14511.83 mb
    Executing bbMPEG.
    Variable Settings:
    Cut point: 791 mb
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\reign of fire\bbMPEG_Muxed_File.mpg"
    - 12/15/2002 12:04:23 AM
    - Free on drive F: 12929.55 mb
    Analyzing: F:\DVD RIP\reign of fire\bbMPEG_Muxed_File00.mpg
    3077.904 seconds F:\DVD RIP\reign of fire\bbMPEG_Muxed_File00.mpg
    Analyzing: F:\DVD RIP\reign of fire\bbMPEG_Muxed_File01.mpg
    3028.032 seconds F:\DVD RIP\reign of fire\bbMPEG_Muxed_File01.mpg
    Analyzing: F:\DVD RIP\reign of fire\bbMPEG_Muxed_File02.mpg
    5.856 seconds F:\DVD RIP\reign of fire\bbMPEG_Muxed_File02.mpg
    Analyzing finished.
    Saving Subtitle Timecodes.
    SVCD subtitles.
    Length of F:\DVD RIP\reign of fire\bbMPEG_Muxed_File00.mpg
    3077
    Length of F:\DVD RIP\reign of fire\bbMPEG_Muxed_File01.mpg
    3028
    Length of F:\DVD RIP\reign of fire\bbMPEG_Muxed_File02.mpg
    5
    - 12/15/2002 12:05:38 AM
    - Free on drive F: 12928.41 mb
    - Multiplexing SVCD Subtitles
    Muxing English subtitles, CD 1
    Executing SubMux. Commandline:
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 "F:\DVD RIP\reign of fire\bbMPEG_Muxed_File00.mpg" "F:\DVD RIP\reign of fire\Subs\en1-1.sub" "F:\DVD RIP\reign of fire\bbMPEG_Muxed_File-subbed00.mpg"
    Muxing English subtitles, CD 2
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 "F:\DVD RIP\reign of fire\bbMPEG_Muxed_File01.mpg" "F:\DVD RIP\reign of fire\Subs\en1-2.sub" "F:\DVD RIP\reign of fire\bbMPEG_Muxed_File-subbed01.mpg"
    Muxing subtitles finished
    - 12/15/2002 12:09:09 AM
    - Free on drive F: 11338.41 mb
    - Creating CD-Images using VCDXBuild
    - No. of chapters to create: 6
    CD image #1: CD_Image_File_CD1.bin
    Executing VCDXBuild. Commandline:
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\reign of fire\CD_Image_File_CD1.cue" --bin-file="F:\DVD RIP\reign of fire\CD_Image_File_CD1.bin" "F:\DVD RIP\reign of fire\VCDXBuild_Script_1.xml"
    - 12/15/2002 12:11:35 AM
    - Free on drive F: 10531.61 mb
    CD image #2: CD_Image_File_CD2.bin
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\reign of fire\CD_Image_File_CD2.cue" --bin-file="F:\DVD RIP\reign of fire\CD_Image_File_CD2.bin" "F:\DVD RIP\reign of fire\VCDXBuild_Script_2.xml"
    CD-Image creation finished.
    - 12/15/2002 12:14:25 AM
    - Free on drive F: 9725.94 mb
    - SVCD Creation finished!
  10. It seems you have encoded a couple of movies in that log file. I am not 100% sure why its doing it. To be honest, one thing I have found with subtitles though is that it allows for the subtitles to take up space on the disk, subs can take up to around 10 megs, its possible something is happening there?, but I am guessing on that one.
    I also noticed your using 1.0.9 try updating to the latest version, www.dvd2svcd.org might help.
    ciao
  11. Originally Posted by TheLostTimberwolf
    ciao
    I just got done ripping GOLDMEMBER and changed the CD SIZE under BITRATE to 780 FOR ALL of them. This time what it did was create 3 disc's but the weird part is it made 2 of them 805Mb and the 3rd one only 7Kb..?? I chose
    Min. bitrate: 300
    Max. bitrate: 2530
    Avg. Bitrate: 2113
    Since the Avg. Bitrate: 2113 WHY didn't it make 2 disc's at a SLIGHTLY better BITRATE instead of making 2 @ 2113 and a 3rd disc that was 8Kb that was i dont have to change the 3rd disc just to watch 5 sec of video??
    Here's the LOG file. Any help is appreciated.....
    Key found: E8C18382BA
    - 12/17/2002 2:20:48 PM
    Initializing
    - 12/17/2002 2:20:53 PM
    Subtitle found (not in ifo file): StreamID: 0x22 Language: Unknown
    Subtitle found: StreamID: 0x22 Language: Unspecified
    Subtitle found (not in ifo file): StreamID: 0x23 Language: Unknown
    Subtitle found: StreamID: 0x23 Language: Unspecified
    Subtitle found (not in ifo file): StreamID: 0x24 Language: Unknown
    Subtitle found: StreamID: 0x24 Language: Unspecified
    Subtitle found (not in ifo file): StreamID: 0x25 Language: Unknown
    Subtitle found: StreamID: 0x25 Language: Unspecified
    - 12/17/2002 2:46:36 PM
    - Free on drive F: 19038.27 mb
    - Internal rip
    Preparing vobfiles to be ripped:
    - E:\VIDEO_TS\VTS_01_1.vob
    - E:\VIDEO_TS\VTS_01_2.vob
    - E:\VIDEO_TS\VTS_01_3.vob
    - E:\VIDEO_TS\VTS_01_4.vob
    Ripping: E:\VIDEO_TS\VTS_01_1.vob
    Ripping: E:\VIDEO_TS\VTS_01_2.vob
    Ripping: E:\VIDEO_TS\VTS_01_3.vob
    Ripping: E:\VIDEO_TS\VTS_01_4.vob
    Ripping finished. Speed: 2441
    Trying to eject the DVD
    - 12/17/2002 3:13:48 PM
    - DVD2AVI
    Variable settings:
    Executing DVD2AVI.
    "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[F:\DVD RIP\goldmember\DVD2AVI_Project_file] -IF=[F:\DVD RIP\goldmember\VTS_01_1.vob,F:\DVD RIP\goldmember\VTS_01_2.vob,F:\DVD RIP\goldmember\VTS_01_3.vob,F:\DVD RIP\goldmember\VTS_01_4.vob]
    Framerate: 23976
    - 12/17/2002 3:17:19 PM
    - Free on drive F: 15150.98 mb
    SVCD Stream no: 1 Language: English Num. of subs: 0
    - 12/17/2002 3:22:01 PM
    - AUDIO Extraction
    Filename: F:\DVD RIP\goldmember\Extracted_audio_1.ac3
    Audio1 delay: 0 ms
    - 12/17/2002 3:25:36 PM
    - Free on drive F: 14848.70 mb
    - AUDIO conversion
    Converting Audio to MP2. Filename: F:\DVD RIP\goldmember\Extracted_audio_1.ac3
    "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "F:\DVD RIP\goldmember\Extracted_audio_1.ac3" -output "F:\DVDRIP~1\GOLDME~1\Encoded_audio_1.mp2" -logfile "F:\DVDRIP~1\GOLDME~1\Encoded_audio_1.log" ) -azid( -L -3db -c normal -g max ) -2lame( -e -b 128 -m s )
    Audio conversion of F:\DVD RIP\goldmember\Extracted_audio_1.ac3 finished.
    - 12/17/2002 3:37:49 PM
    - Free on drive F: 14762.30 mb
    - 12/17/2002 3:37:55 PM
    - Free on drive F: 14761.48 mb
    StreamSectors: 1624647976
    AudioSectors: 91963004
    VideoPAPO: 23742108
    ScanOffsetBytes: 163100
    SeqAligningBytes: 10365937
    DVDBytes: 0
    VideoEndHeader: 8
    SubtitleSectors: 0
    PureMPEGStream: 1498413819.07
    Seconds: 5670.88
    CalcMPEGStream: 1498413819.07
    Frames: 135917
    CDSize: 780.00
    Cut point 774.00
    Variable Settings:
    Frames: 135917
    Passes: 4
    Image Quality: 17
    Min. bitrate: 300
    Max. bitrate: 2530
    Avg. Bitrate: 2113
    Aspect Ratio: 4:3 (No borders, encoded as 4:3)
    ---AVS Begin---
    mpeg2source("F:\DVDRIP~1\GOLDME~1\DVD2AV~1.D2V")
    SimpleResize(480,480)
    ----AVS End----
    Closing program
    CCE Max Speed: 1.530
    - 12/17/2002 8:49:19 PM
    - Free on drive F: 13265.70 mb
    - Video Pulldown
    "C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "F:\DVD RIP\goldmember\Encoded_Video_CCE_NTSC.mpv" "F:\DVD RIP\goldmember\Pulldown_Encoded_Video_NTSC.mpv"
    - 12/17/2002 8:53:51 PM
    - Free on drive F: 11838.02 mb
    - 12/17/2002 8:53:53 PM
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\goldmember\ChangeCDPicture.bmp.mpg"
    - 12/17/2002 8:53:58 PM
    - Free on drive F: 11837.95 mb
    Executing bbMPEG.
    Variable Settings:
    Cut point: 774 mb
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\goldmember\bbMPEG_Muxed_File.mpg"
    - 12/17/2002 9:01:53 PM
    - Free on drive F: 10287.41 mb
    Analyzing: F:\DVD RIP\goldmember\bbMPEG_Muxed_File00.mpg
    2726.568 seconds F:\DVD RIP\goldmember\bbMPEG_Muxed_File00.mpg
    Analyzing: F:\DVD RIP\goldmember\bbMPEG_Muxed_File01.mpg
    2921.688 seconds F:\DVD RIP\goldmember\bbMPEG_Muxed_File01.mpg
    Analyzing: F:\DVD RIP\goldmember\bbMPEG_Muxed_File02.mpg
    6.696 seconds F:\DVD RIP\goldmember\bbMPEG_Muxed_File02.mpg
    Analyzing finished.
    - 12/17/2002 9:02:59 PM
    - Free on drive F: 10287.39 mb
    - No. of chapters to create: 7
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\goldmember\CD_Image_File_CD1.cue" --bin-file="F:\DVD RIP\goldmember\CD_Image_File_CD1.bin" "F:\DVD RIP\goldmember\VCDXBuild_Script_1.xml"
    - 12/17/2002 9:05:28 PM
    - Free on drive F: 9502.75 mb
    - No. of chapters to create: 12
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\goldmember\CD_Image_File_CD2.cue" --bin-file="F:\DVD RIP\goldmember\CD_Image_File_CD2.bin" "F:\DVD RIP\goldmember\VCDXBuild_Script_2.xml"
    - 12/17/2002 9:08:09 PM
    - Free on drive F: 8718.16 mb
    CD image #3: CD_Image_File_CD3.bin
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\goldmember\CD_Image_File_CD3.cue" --bin-file="F:\DVD RIP\goldmember\CD_Image_File_CD3.bin" "F:\DVD RIP\goldmember\VCDXBuild_Script_3.xml"
    - 12/17/2002 9:08:12 PM
    - Free on drive F: 8715.58 mb
  12. Well it happened AGAIN..!! This time i used the DEFAULT settings under BITRATE and this time it made 2-bin files 760Mb and the 3rd-bin file 100Mb. Again i've posted the LOG file. Can someone PLEASE tell me what setting I have set incorrect....THANKS....
    Key found: EE8B94F251
    - 12/17/2002 11:25:28 PM
    Initializing
    - 12/17/2002 11:25:33 PM
    Subtitle found: StreamID: 0x22 Language: Franįais
    - 12/17/2002 11:26:03 PM
    - Free on drive F: 18987.25 mb
    - Internal rip
    - E:\VIDEO_TS\VTS_01_5.vob
    - E:\VIDEO_TS\VTS_01_6.vob
    - E:\VIDEO_TS\VTS_01_7.vob
    - E:\VIDEO_TS\VTS_01_8.vob
    Ripping: E:\VIDEO_TS\VTS_01_5.vob
    Ripping: E:\VIDEO_TS\VTS_01_6.vob
    Ripping: E:\VIDEO_TS\VTS_01_7.vob
    Ripping: E:\VIDEO_TS\VTS_01_8.vob
    Ripping finished. Speed: -92
    - 12/18/2002 12:15:34 AM
    - DVD2AVI
    Variable settings:
    Executing DVD2AVI.
    "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[F:\DVD RIP\mr\DVD2AVI_Project_file] -IF=[F:\DVD RIP\mr\VTS_01_1.vob,F:\DVD RIP\mr\VTS_01_2.vob,F:\DVD RIP\mr\VTS_01_3.vob,F:\DVD RIP\mr\VTS_01_4.vob,F:\DVD RIP\mr\VTS_01_5.vob,F:\DVD RIP\mr\VTS_01_6.vob,F:\DVD RIP\mr\VTS_01_7.vob,F:\DVD RIP\mr\VTS_01_8.vob]
    Framerate: 23976
    - 12/18/2002 12:21:10 AM
    - Free on drive F: 11409.39 mb
    SVCD Stream no: 1 Language: English Num. of subs: 1701
    - 12/18/2002 12:30:03 AM
    - Free on drive F: 11381.00 mb
    - AUDIO Extraction
    Filename: F:\DVD RIP\mr\Extracted_audio_1.ac3
    Audio1 delay: 0 ms
    - 12/18/2002 12:36:06 AM
    - Free on drive F: 10915.72 mb
    - AUDIO conversion
    Converting Audio to MP2. Filename: F:\DVD RIP\mr\Extracted_audio_1.ac3
    "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "F:\DVD RIP\mr\Extracted_audio_1.ac3" -output "F:\DVDRIP~1\mr\Encoded_audio_1.mp2" -logfile "F:\DVDRIP~1\mr\Encoded_audio_1.log" ) -azid( -L -3db -c normal -g max ) -2lame( -e -b 128 -m s )
    Audio conversion of F:\DVD RIP\mr\Extracted_audio_1.ac3 finished.
    - 12/18/2002 12:51:20 AM
    - Free on drive F: 10815.42 mb
    - 12/18/2002 7:30:48 AM
    Initializing
    - 12/18/2002 7:30:57 AM
    - Free on drive F: 10800.33 mb
    - Crash Recovery
    - Restarting from: Audio Extraction
    - 12/18/2002 7:30:58 AM
    - AUDIO Extraction
    Audio1 delay: 0 ms
    - 12/18/2002 7:39:44 AM
    - Free on drive F: 10798.55 mb
    - AUDIO conversion
    - 12/18/2002 7:57:49 AM
    - Free on drive F: 10765.88 mb
    - 12/18/2002 7:57:55 AM
    StreamSectors: 2309384364
    AudioSectors: 141308496
    VideoPAPO: 33584652
    ScanOffsetBytes: 250654
    SeqAligningBytes: 15930429
    DVDBytes: 0
    VideoEndHeader: 12
    SubtitleSectors: 7931812
    PictureSectors: 600.00
    PureMPEGStream: 2110378309.60
    Seconds: 8713.96
    CalcMPEGStream: 2110378309.60
    Frames: 208878
    CDSize: 740.00
    Cut point 731.00
    Variable Settings:
    Frames: 208878
    Passes: 4
    Image Quality: 17
    Min. bitrate: 300
    Max. bitrate: 2530
    Avg. Bitrate: 1937
    ---AVS Begin---
    mpeg2source("F:\DVDRIP~1\mr\DVD2AV~1.D2V")
    ----AVS End----
    Closing program
    CCE Max Speed: 1.640
    - 12/18/2002 4:13:54 PM
    - Free on drive F: 8354.48 mb
    - Video Pulldown
    "C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "F:\DVD RIP\mr\Encoded_Video_CCE_NTSC.mpv" "F:\DVD RIP\mr\Pulldown_Encoded_Video_NTSC.mpv"
    - 12/18/2002 4:20:27 PM
    - Free on drive F: 6338.73 mb
    - 12/18/2002 4:20:30 PM
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\mr\ChangeCDPicture.bmp.mpg"
    - 12/18/2002 4:20:34 PM
    - Free on drive F: 6338.67 mb
    Executing bbMPEG.
    Variable Settings:
    Cut point: 731 mb
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "F:\DVD RIP\mr\bbMPEG_Muxed_File.mpg"
    - 12/18/2002 4:32:10 PM
    - Free on drive F: 4144.39 mb
    - 12/18/2002 4:49:08 PM
    Initializing
    - 12/18/2002 4:49:15 PM
    - Free on drive F: 4146.14 mb
    - Crash Recovery
    - 12/18/2002 4:49:16 PM
    - 12/18/2002 10:14:18 PM
    Initializing
    - 12/18/2002 10:14:25 PM
    - Free on drive F: 4110.67 mb
    - Crash Recovery
    - 12/18/2002 10:14:26 PM
    Analyzing: F:\DVD RIP\mr\bbMPEG_Muxed_File00.mpg
    3014.472 seconds F:\DVD RIP\mr\bbMPEG_Muxed_File00.mpg
    Analyzing: F:\DVD RIP\mr\bbMPEG_Muxed_File01.mpg
    2677.416 seconds F:\DVD RIP\mr\bbMPEG_Muxed_File01.mpg
    Analyzing: F:\DVD RIP\mr\bbMPEG_Muxed_File02.mpg
    3000.865 seconds F:\DVD RIP\mr\bbMPEG_Muxed_File02.mpg
    Analyzing: F:\DVD RIP\mr\bbMPEG_Muxed_File03.mpg
    14.136 seconds F:\DVD RIP\mr\bbMPEG_Muxed_File03.mpg
    Analyzing finished.
    SVCD subtitles.
    Length of F:\DVD RIP\mr\bbMPEG_Muxed_File00.mpg
    3014
    Length of F:\DVD RIP\mr\bbMPEG_Muxed_File01.mpg
    2677
    Length of F:\DVD RIP\mr\bbMPEG_Muxed_File02.mpg
    3000
    Length of F:\DVD RIP\mr\bbMPEG_Muxed_File03.mpg
    14
    - 12/18/2002 10:16:03 PM
    - Free on drive F: 4109.05 mb
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 "F:\DVD RIP\mr\bbMPEG_Muxed_File00.mpg" "F:\DVD RIP\mr\Subs\en1-1.sub" "F:\DVD RIP\mr\bbMPEG_Muxed_File-subbed00.mpg"
    - 12/19/2002 12:31:48 PM
    Initializing
    - 12/19/2002 12:32:17 PM
    - Free on drive F: 3602.05 mb
    - Crash Recovery
    - 12/19/2002 12:32:18 PM
    Analyzing finished.
    SVCD subtitles.
    3014
    2677
    3000
    14
    - 12/19/2002 12:34:00 PM
    - Free on drive F: 3602.03 mb
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 "F:\DVD RIP\mr\bbMPEG_Muxed_File01.mpg" "F:\DVD RIP\mr\Subs\en1-2.sub" "F:\DVD RIP\mr\bbMPEG_Muxed_File-subbed01.mpg"
    Muxing English subtitles, CD 3
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" -s0 "F:\DVD RIP\mr\bbMPEG_Muxed_File02.mpg" "F:\DVD RIP\mr\Subs\en1-3.sub" "F:\DVD RIP\mr\bbMPEG_Muxed_File-subbed02.mpg"
    - 12/19/2002 12:38:41 PM
    - Free on drive F: 1906.58 mb
    - No. of chapters to create: 8
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\mr\CD_Image_File_CD1.cue" --bin-file="F:\DVD RIP\mr\CD_Image_File_CD1.bin" "F:\DVD RIP\mr\VCDXBuild_Script_1.xml"
    - 12/19/2002 12:40:52 PM
    - Free on drive F: 1161.28 mb
    - No. of chapters to create: 9
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\mr\CD_Image_File_CD2.cue" --bin-file="F:\DVD RIP\mr\CD_Image_File_CD2.bin" "F:\DVD RIP\mr\VCDXBuild_Script_2.xml"
    - 12/19/2002 12:43:13 PM
    - Free on drive F: 416.81 mb
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="F:\DVD RIP\mr\CD_Image_File_CD3.cue" --bin-file="F:\DVD RIP\mr\CD_Image_File_CD3.bin" "F:\DVD RIP\mr\VCDXBuild_Script_3.xml"
    - 12/19/2002 12:43:36 PM
    - Free on drive F: 314.38 mb
  13. the problem you describe i know and have experienced. making files that are pointless like 7 kb i even had one at 4kb. I thought it was cause i was trying to force too much video (time) into too little space (megabytes).
    I think the encoding programs dont stick to their bitrates 100% and sometimes this can cause the end file to be larger than desired creating the pointless small files. As bbMpeg will always cut based on file size.
    Why do all your conversions encode the audio twice after a crash recovery? You trying to use batch encoding?
    ciao
    TLTw
    Dec 2002
    Side Note: Most DVD's wind up as 3 SVCD's. Longer movies like Lord of the Rings are 4. I have always had great luck with bitrates by reducing my calculations 10%. That is whatever "I think" I need for XviD or SvcD, I reduce 10 % and I'm never too big. Min/Max/Average is not 100% carved in stone. Particullary the average. It can try and get real close, but only a 2-pass encode will hit it spot on.
    And about 8 KB 3rd disks. To be brutally honest, do you need to see the last 2 seconds of the credits. All of the old DivX types know what credits are for: To trim off to hit disk size!
    I'm wondering if your actually running out of space in the middle of the job. You had 300+ MB when finished. Temp files during the processing?
  15. true that and i do agree, but when making a svcd for watching at home that dont need downloading, i prefer the whole thing. DivX is mainly used for net distribution so credits and other similar things are extra download, so removing them is understandable
  16. Originally Posted by TheLostTimberwolf
    ciao
    TLTw
    The only reason it should of encoded the AUDIO twice is because I did 2 CRASH RECOVERYS. BTW I finished UNFAITHFUL today and used 800 for ALL CD sizes and THIS TIME it made the 1st CD TOO BIG so i had to OVERBURN it. This program DEFINATELY has problems calculating the disc size properly.
    CDSize: 800.00
    Cut point 792.00
    To me "Cut point 792.00" means DON'T MAKE the file size BIGGER then 792 mB...
  17. Here's my most RECENT rip......
    I redid GOLDMEMBER AGAIN and it did the SAME THING AGAIN.. It made a 3rd CD 8Kb. The Avg. Bitrate: 1965 could of been increased to a Max. Avg. of 2230 instead of creating the 3rd disk. I've updated to DVD2SVCD 1.1.0 BUILD 1C. Under Executing
    Cinema Craft Encoder it says a few things Im unclear about.
    #1 - Number of CDs: 2 Yet it made 3
    #2 - Avg. Bitrate: 1965 Yet the Max. Avg. is set for 2230
    WNASPI32.DLL 4.5.7.1008
    - 12/22/2002 10:19:06 AM
    - DVD2SVCD ver. 1.1.0 build 1c
    Initializing
    - 12/22/2002 10:19:08 AM
    - 12/22/2002 10:44:19 AM
    - Free on drive C: 20625.09 mb
    - Internal rip
    Ripping finished. Speed: 2381
    - 12/22/2002 11:12:13 AM
    - DVD2AVI
    Variable settings:
    Executing DVD2AVI.
    "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\DVD
    RIP\goldmember\DVD2AVI_Project_file] -IF=[C:\DVD RIP\goldmember\VTS_01_1.vob,C:\DVD
    RIP\goldmember\VTS_01_2.vob,C:\DVD RIP\goldmember\VTS_01_3.vob,C:\DVD
    Framerate: 23976
    - 12/22/2002 11:15:26 AM
    - Free on drive C: 16747.05 mb
    - 12/22/2002 11:19:06 AM
    - Free on drive C: 16746.82 mb
    - AUDIO Extraction
    Filename: C:\DVD RIP\goldmember\Extracted_audio_1.ac3
    Audio1 delay: 0 ms
    - 12/22/2002 11:23:53 AM
    - Free on drive C: 16444.50 mb
    - AUDIO conversion
    Encoding Audio. Filename: C:\DVD RIP\goldmember\Extracted_audio_1.ac3
    "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\DVD
    "C:\DVDRIP~1\GOLDME~1\Encoded_audio_1.mp2" -logfile
    "C:\DVDRIP~1\GOLDME~1\Encoded_audio_1.log" ) -azid( -L -3db -c normal -s surround -g
    max ) -2lame( -e -b 160 -m s )
    Audio conversion of C:\DVD RIP\goldmember\Extracted_audio_1.ac3 finished.
    - 12/22/2002 11:37:01 AM
    - Free on drive C: 16336.64 mb
    - 12/22/2002 11:37:10 AM
    - Free on drive C: 16335.84 mb
    StreamSectors: 1540983976
    AudioSectors: 114952012
    VideoPAPO: 22089996
    DVDBytes: 0
    VideoEndHeader: 8
    SubtitleSectors: 0
    PureMPEGStream: 1393412923.07
    Seconds: 5670.88
    CalcMPEGStream: 1393412923.07
    Frames: 135917
    CDSize: 740.00
    Number of CDs: 2
    Cut point 734.00
    Variable Settings:
    Frames: 135917
    Passes: 4
    Image Quality: 17
    Avg. Bitrate: 1965
    ---AVS Begin---
    mpeg2source("C:\DVDRIP~1\GOLDME~1\DVD2AV~1.D2V")
    BicubicResize(480,480,0.0,0.6)
    ----AVS End----
    Closing program
    CCE Max Speed: 1.460
    - 12/22/2002 12:42:37 PM
    - Free on drive C: 14974.77 mb
    - Video Pulldown
    "C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "C:\DVD
    RIP\goldmember\Encoded_Video_CCE_NTSC.mpv" "C:\DVD
    - 12/22/2002 12:47:09 PM
    - Free on drive C: 13646.99 mb
    - 12/22/2002 12:47:11 PM
    - Free on drive C: 13646.98 mb
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\DVD
    - 12/22/2002 12:47:15 PM
    - Free on drive C: 13646.95 mb
    - 12/22/2002 12:47:17 PM
    Executing bbMPEG.
    Variable Settings:
    Cut point: 734 mb
    - 12/22/2002 12:58:48 PM
    - Free on drive C: 12178.78 mb
    Analyzing: C:\DVD RIP\goldmember\bbMPEG_Muxed_File00.mpg
    2830.200 seconds C:\DVD RIP\goldmember\bbMPEG_Muxed_File00.mpg
    Analyzing: C:\DVD RIP\goldmember\bbMPEG_Muxed_File01.mpg
    2824.944 seconds C:\DVD RIP\goldmember\bbMPEG_Muxed_File01.mpg
    Analyzing: C:\DVD RIP\goldmember\bbMPEG_Muxed_File02.mpg
    0.000 seconds C:\DVD RIP\goldmember\bbMPEG_Muxed_File02.mpg
    Analyzing finished.
    - 12/22/2002 1:00:16 PM
    - Free on drive C: 12178.77 mb
    --cue-file="C:\DVDRIP~1\GOLDME~1\CD_Image_File_CD1.cue"
    --bin-file="C:\DVDRIP~1\GOLDME~1\CD_Image_File_CD1.bin"
    "C:\DVDRIP~1\GOLDME~1\VCDXBU~1.XML"
    - 12/22/2002 1:04:11 PM
    - Free on drive C: 11434.66 mb
    - No. of chapters to create: 11
    --cue-file="C:\DVDRIP~1\GOLDME~1\CD_Image_File_CD2.cue"
    --bin-file="C:\DVDRIP~1\GOLDME~1\CD_Image_File_CD2.bin"
    "C:\DVDRIP~1\GOLDME~1\VCDXBU~2.XML"
    - 12/22/2002 1:07:58 PM
    - Free on drive C: 10690.61 mb
    - No. of chapters to create: 19
    --cue-file="C:\DVDRIP~1\GOLDME~1\CD_Image_File_CD3.cue"
    --bin-file="C:\DVDRIP~1\GOLDME~1\CD_Image_File_CD3.bin"
    "C:\DVDRIP~1\GOLDME~1\VCDXBU~3.XML"
    - 12/22/2002 1:08:02 PM
    - Free on drive C: 10688.41 mb
  18. have you tried using different rippers?
    Smart Ripper, DVD Decrytor, or try using V-Strip from within dvd2svcd?
    then just load the ifo and convert. might work?
    good luck...
  19. Originally Posted by TheLostTimberwolf
    good luck...
    I "use internal routines" in DVD2SVCD itself to RIP the DVD. I've used SmartRipper in the past but not recently just because I like being able to click on a few tabs, Hit Run and come back 3hrs later to BURN my CD's.
  20. Well in a last dash attampt, with the latest dvd2svcd theres a little box you can check under the Conversion Tab called Frame Selection. Basically its the equivilant to Source Range in TMPGEnc. One thing I noticed is that it disables automatic cutting by bbMpeg. So you just set up how many different parts you want and let it encode as per usual.
    Outside of that I honestly dont know what causes it to happen, I find when it does happen though if I take the seperate video and audio streams and put them together nero always says theres an invalid stream, with no details and it always seem to be larger than it should be.
    One day when I get off My lazy ass and learn to code I might understand lol, good luck dude
    see ya...
  21. I use Smart ripper, DVD2AVI, TMPGE, Chapter Xtractor, VCD Easy, like listed in the newbie section and have good results. Also I am using 99min CD's this enables you to get a full VCD on one disc. My stand alone DVD player plays them also.
    Hope this helps.
