  1. Does anyone know an adress, where I can download an MPEG2 Plugin for TMPGENC? or a usefull way how I can handle the link on the Tool-Section in this site? I didnt figure it out....
    Pleas help...
    Thanx
  2. Just pay the money to register it, and the MPEG-2 encoding will work forever.
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. You missunderstood!
    I want to re-encode MPEG2 Files.
    But I can't open the File
  4. Member Conquest10's Avatar
    Chicago, IL
    you should be able to if you have the plus version.
  5. Seems the sites that hosted it are down. You can email me and I will send it over to you.
  6. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    The best solution is to frameserve when you need to re-encode mpeg 2 files.
    Use dvd2avi for this. You can found the proggy on the Tools section and how to do it on the convertion section of this site.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If you install PowerDVD, (or was it WinDVD - I keep forgetting, but I'm pretty sure it's Power (gotta mark that sector of my brain as damaged )), TMPGEnc will use the MPEG2 decoder of PowerDVD to decode MPEG2 input.
    /Mats
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep, install powerdvd and you can open mpeg2 in tmpgenc.
