Can a CD-RW be used in EZ CD Creator or Nero like a CD-R disc ? The only way I seem to be able to use a CD-RW is through DirectCD or InCD.
Tom
Yes you can use CD-RWs, but they have to be erased first. DO NOT <format> them with DirectCD. Use <Erase CD-RW> (You may need to update DirectCD for this). You should fit over an hours worth of VCD on a CD-RW, but you have to erase them again each time you want to burn a VCD. Say the word and I'll Email you the update (1.45 meg). I'm sure Adaptec won't mind.
adaptec won't but roxio might.
i dun like that company.
nero is better.
BD -RE Discs
By pepegot1 in forum Authoring (Blu-ray)Replies: 3Last Post: 7th May 2011, 16:30 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Anybody used these discs?
By biged670 in forum MediaReplies: 3Last Post: 23rd Apr 2009, 03:30 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 22:29 -
how do i bk up these discs
By aberboy0 in forum DVD RippingReplies: 1Last Post: 10th Dec 2007, 22:34
