Thanks!!
Results 1 to 17 of 17
i use coverxp. there are various templates that come with the software. you just have to find the right one 8)
i only make svcd's. covers always come out great. did you check your printer settings? if the settings are ok,then its your template,try another.
you can also try the "support" section of the coverxp site. -
I just use paintshop pro, resize to the correct size. Then print.
Craig has it right,
Measure the case to get the size you want, in inches or cm or mm or what ever. then resize the cover within most decent graphic apps, paint shop pro works fine, to the same size, keeping the unit of measure the same, dont worry about how big it looks on screen etc, as long as the measurements are correct.
good luck :PThe Hellsing family will purify this world... -
Hey dude, try this
scan in a cover, you know this works, then use that to work from with your downloaded ones. Make your downloaded ones match its same size and it should come out ok.
Try this, see how you goThe Hellsing family will purify this world... -
I have a template that I use for making my own DVD covers in PSP. I can send it to you if you like.
What is avy, one of the templates was jpeg so just about every decent graphics package should open it
could you please email me one of your covers with the measurements in inches or cm which ever you use for the dvd cover?. Im getting curious with this one
TheLostTimberwolf@hotmail.com
ciaoThe Hellsing family will purify this world... -
Originally Posted by canadateck
