Hey there,
I am fairly new to this whole thing. I have avi's that I convert to VCD using TMPGEnc. The initial file is usually about 400mg and after I encode it, it often exceeds 800/900mg. So, when I try to burn using Nero, it is too big for the disk. I am wondering if I am missing some setting that will compress the files more or is this the norm.
Thanks a lot!!
M
answer this questions and maybe I can help.
1. How long in minutes is this file?
If it is less than 80 minutes it will fit on an 700mb/80min cd-r.
If it is more than 80 minutes you have to cut it into two or more pieces (cd-r)
If you need to cut it into pieces click on edit (to your left).
Let me know if I can help
Signed
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked?
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Creating Clips effectively from large mpegs -- HDD Cameras
By bryan andrews in forum EditingReplies: 1Last Post: 22nd Jan 2009, 10:36 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 16:53 -
TubeStick and splitting large mpegs
By benblack in forum MacReplies: 7Last Post: 30th Sep 2007, 14:11
