  1. I'm using TMPGEnc to covert about 60 MOV files to mpg so I can put them on a VCD.
    Right now I'm having to do them one at a time.
    Can anyone tell me how, or even if, TMPGEnc can batch these all into one job? I see a batch encode in the menu but I don't seem to be able to figure out how it works.
  2. when your done tweaking your settings for your first file to be encoded dont click start encoding. click batch encode. and it will take you to the wizard again. keep doing that untill your ready to encode then click start encoding on your last file you wish to add to job list and click start.
    go to bed and wake up to encoded files.
  3. THANKYOU!!!
    Not quite as easy as I was looking for - I wanted to hightlight about 40 small .MOVs and have them all be converted.
    Still a lot easier than waiting on them one at a time like I was doing.
    Thanks again hoola_loop!
