Excellent Site.
I am wanting to burn copies of my DVDs to SVCD Format on blank CD-R's. Can you use a CD recorder/DVD rom COMBO drive to do this? Or do you have to have 2 separate drives?
You should be able to use the combo drive.
As you are going to use both fiunctions, but not at the same time.
I would suggest you do some reading. Start with the What is then move onto the How to. Which are on the left side of page. Then if you have more qustions ask. Their is a wealth of info here. And it will take some time to comprehend it all.
And this is an Excelent site, Baldrick has done a Fantastic jobMay the force be with you.
Dumb Question - Burning Blu-Ray movie with a standard DVD-R burner?
By toxicquack in forum Authoring (Blu-ray)Replies: 7Last Post: 18th Aug 2009, 03:59 -
Question: DVD, CD or ROM DYE LIFE
By mjk4ty in forum MediaReplies: 1Last Post: 10th Feb 2008, 19:18 -
Question about new DVD-burner
By Videonator in forum DVD & Blu-ray WritersReplies: 8Last Post: 7th Oct 2007, 04:39 -
Just another DVD burner question...
By newbie3 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Sep 2007, 19:47 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 11:37
