Hello, I just wanted to let you know what method I use before I ask my question. I used SmartRipper, then DVD2AVI, TMPGenc, Chapter Xtractor, DVD Maestro, finally Gear Pro to burn. My question is, if I am burning a relatively short DVD, such as Rush Hour 2, or any DVD under 1 45 min, and I don't need subtitles or any other special features, is there a way to see if I have extra room on the DVD-R to bump up the bitrate, and if so, how would I know how much too add to the bitrate? Any help would be much appreciated! Thanks alot!
Patgreenwell06@aol.com
well most dvds that are under 2 hours can be copyied without any encoding. it will be a perfect copy as the orginal. all you need is DVD Decrypter....
Are you sure? Even if it is about 1hr and 45 min? If this is true, can you please tell me the step by step process, because I thought for all DVD's you must encode them.
well there is one catch. the dvd has to be under 4.7 gigs. if so you run DVD Decrypter. go to mode and click on iso and click on read. it will make a iso image to your hard drive. once done run DVD Decrypter load your iso image and go to mode click on iso and then click on write. now it will burn the image to blank dvd media. perfect copy...
But if it is not under 4.7 GB in DVD Decryptor, then is there any extra space on the DVD-R if I don't want menus and extra's? What I mean is, how can I tell if there is any extra space left on the disc after I have my final project ready to burn? Do you see what I mean?
well if it is not under 4.7 you will have to encode the video in order for it to fit...
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
