  1. Hi all, I hope you can help.
    I have a movie that is already an mpg file (mpg1). I wanted to chapter it. So I opened vcdeasy and chose vcd (rather than svcd, which I know has to be mpg2). For some reason, when I went to chapter it, it only showed just over 4 minutes as able to chapter. It shows Approximate file size as 772mb on the front page but not on the chapter page.
    The file plays in WMP just fine, the entire 1hr 16min of movie.
    Please help as to what I can do/try next!
    Thank you!
    Jenny
    jrarden@sbcglobal.net
  2. Don't know if it will work but it's worth a shot. Try to demultiplex and multiplex the file in tmpgenc and see if that helps.
  3. Hi there from a fellow-dvd to vcd fan.
    Ensure your file is a valid mpeg 1.
    WMP or any pc type player, plays about anything.
    Vcdeasy checks compliancy. Enable check compliancy in vcdeasy.
    Visit this site below for guide on chapters. It might help you!
    Visit this great site where you can download some real amazing templates for TmpGenc!! (Or any encoder)
    Proven templates with the highest quality possible before Dvd.
    Settings that work. No lies about fitting a dvd to 1 cd-r!
    Get real results with tested templates. CVD works unbelievable.
    Get no blocknoise and learn more tricks to remove artifact in backgrounds.
    PLUS loads of free downloads and some more real cool deals!
    Hope to see you visit "The DV-Basket" soon!!!!
    Click here: http://www.creativedimension.co.za/millware/studiostor/info.htm
