I'm encoding .avi to SVCD NTSC. When I go to encode purple lines go across the screen. Will these show up in the movie and if so how do I fix it?
Yes. Try change the directshow priority in tmpgenc and then open the avi and check if you see any purple lines.
www.vcdhelp.com/tmpgenc#problems -
I changed it to a 1 and it said the format is unsuported then I changed it to 2 and it said the same thing. I even went up to 5 but no change.
Lines On Desktop
By jjis in forum ComputerReplies: 4Last Post: 16th Dec 2010, 14:11 -
Why are there lines in my video?
By Mysteriouskk in forum Video ConversionReplies: 8Last Post: 6th Dec 2007, 21:30 -
Where do these lines come from?
By RedFarmer in forum Capturing and VCRReplies: 8Last Post: 6th Nov 2007, 06:13 -
What are these lines?
By Dr.Gee in forum Newbie / General discussionsReplies: 14Last Post: 14th Sep 2007, 13:17 -
Lines
By snake2589 in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 19:08
