Having some problems with getting good quality on my VCDs. I tried almost everything. What format and framrate gives the best result?
Let's say I get a movie file in avi format. How can I be sure that one gives me DVD like quality when converting and burning it to e.g. SVCD?
I get jumpy and bad quality movies. The colors are wrong, if any, and the focus and resolutions are bad. I don't even get the picture format correct. Gets black and greylike color around the picture on the TV screen.
You may call me a lamer to this, but how the h... do I get it right?
/Anders
To get it right its just like anything else. Practice, try things, ask questions (specific ones not vague enquiries like this) and keep trying. If you are patient and keen you will learn what to do to achieve your desired results, if not you will give up and do something else.You may call me a lamer to this, but how the h... do I get it right?
Just read every guide you can find, try every technique and tool mentioned until you find the method that suits you and gives you what you want.
Just to get you started, TmpGenc is a great if rather slow encoder, also easy to use. Nero is OK for burning though other will suggest other tools. Make sure you encode your mpeg with the same framerate as the avi whenever possible.
Hope this helps
When you can't get the LFE to result in what you want...
By takearushfan in forum AudioReplies: 0Last Post: 15th Feb 2012, 23:44 -
MKVextractGUI: extracted video result in .h264 format instead of .mp4
By shichi00 in forum Video ConversionReplies: 1Last Post: 19th Mar 2010, 04:28 -
Result movie from Automkv.
By chuckman78 in forum Video ConversionReplies: 2Last Post: 20th Aug 2008, 14:24 -
Choppy Result
By darkdog in forum ffmpegX general discussionReplies: 1Last Post: 22nd Mar 2008, 23:32 -
DVD Ripping-poor result
By pauldb in forum DVD RippingReplies: 8Last Post: 6th Aug 2007, 20:31
