I've got a big problem. The menus on VCDs that I created with VCD Toolkit don't work. When I press the numeric buttons on the remote control, nothing happens!
Does anybody know what I could have done wrong?
Did you drag and drop your menu, event or sequence objects to the "+" symbol on the main menu object? Each object you drop will be assigned a numeric value.
RF
<font size=-1>[ This Message was edited by: RFontenot on 2001-08-26 21:35:41 ]</font>
"Toolkit" for using a laptop to play video and audio onto a tv
By bobogs in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 20:49 -
Software Problem NTI Media maker no menus
By music_freak in forum Authoring (DVD)Replies: 3Last Post: 19th May 2009, 17:32 -
problem with menus when burning VIDEO_TS files to DVD
By samd292 in forum MacReplies: 3Last Post: 24th Jun 2008, 08:49 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16 -
Problem with DVDlab and 16:9 motion menus
By sektionschef in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 05:11
