i tried encoding star wars to vcd using DVD2SVCD but something went wrong and it came out all messed up (out of sync and freezing) but its too long to fit as SVCD by about 5 mins so if i cut the credits off the end it should fit as svcd. What can i use to edit the last vob fle so it'll fit?![]()
Results 1 to 1 of 1
cutting a vob to edit the clip and later merge with original without re-enc
By Srivas in forum EditingReplies: 4Last Post: 25th Dec 2010, 02:37 -
Cutting VOB File without any quality loss? (ending credits)
By willhenderson in forum Newbie / General discussionsReplies: 10Last Post: 15th Oct 2008, 23:45 -
Is VobBlanker good for cutting parts off of VOb files???
By mabhz in forum EditingReplies: 5Last Post: 28th Jul 2008, 04:01 -
Cutting VOB files
By DELTAsnake in forum EditingReplies: 20Last Post: 6th Apr 2008, 17:23 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 09:52
