  1. hi guys,
    i keep getting an error message while trying to rip some avi files from some cd's, The message says: "Data error (Cyclic redundancy check). the avi's seem to play ok from cd, but there are just a few that wont be ripped?
    Can anyone help?
  2. you mean u had problems copying .avi files from your CD-R to your hd???
    windows explorer shouldn't have problems copying files over...make sure you use "copy" and not "move"
  3. yeah, most of them copy to my hard drive fine, but there is a couple on each disk that give me this error message?
  4. u have multiple computers on a network??? if you do, you can try sharing a computer's cd-rom on the network and then copying the file from that computer's cd-rom to another computer's hd.
    i believe i had similar problems too, but rather in copying the .mpg file from SVCD discs
  5. yeah, i just tried that, but still no luck??
