  1. I downloaded a movie last night and after I rared it I had a bin/cue file. All good for now. I used CdrWin and had no problem. The speed I used was 8x(max). Not sure if that matters. I then threw it in my DVD player and on the LCD screen it said no disc. Now I have a Toshiba DV-P305 and can't find anywhere if it plays VCD's, but on the front panel of the player it says DVD's, CD's and Video Discs. I'm assuming that it plays it. Can anyone help me with this and let me know another wya to go.
    Thanks Keil
  2. Video disk is a vcd
    sounds like it does not play that type of cdr or cdrw,
  3. Hmm so I guess I need a DVD player that does?
  4. Well, only if you tend to "throw out the baby with the bath water." Before replacing your DVD player, you might try using some other brands of discs first.
