dvd-r/rw's are quite expensive in ireland, so imagine my surprise when i went into my local pc world and found they were selling pioneer dvd-rw's for just 2.98 each (euro)! i bought 10 of them. however, i have found the discs have CPRM- Copy Protection for Recordable Media. has anyone come across discs with this? i hope it only means i cant make copies of these discs on the fly with nero. the disc labels say
"cprm is the copy protection system with scrambling system regarding the recording of "copy once" broadcating program."
anyone know exactly how CPRM works?
I do not know what it does but I do know that I had some princo dvd-rws that had it and they work fine for copying dvds. I think they will work fine using the common dvd back up methods with these discs.
yeah epo i was thinking the same. if you put one of these discs in a set-top recorder and try to record an encrypted channel the cprm kicks in.
CPRM is likely to be just as effective as CSS has been.
Some "features" of CPRM:
1) Identification of the media type in the lead-in area, so if info that has been intended only for ROM media has been detected on a R/W disk, a CPRM complient player will refuse playback.
2) The area where the CSS decryption key normally goes is pre-embossed to prevent bit for bit copies (this is also on a -R disk).
3) Unique serialization for each disk.
4) Allowance for one copy (using a CPRM complient recorder).
In short, CPRM will just be another hurdle that will need to be cracked to give the end-user full access to his fair-use rights. (As far as I can tell, CPRM only applies to -R/W media.)
Another false positive virus threat? ff_vfw.dll
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2010, 14:06 -
.IVA file a real threat or not?
By hitman3000 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2008, 17:05 -
Newest empty threat from eBay sellers!
By lordsmurf in forum Off topicReplies: 3Last Post: 5th Aug 2007, 09:57 -
CPRM - Uncrackable?
By hatchling in forum DVD RippingReplies: 4Last Post: 10th Jun 2007, 18:58 -
Apple, others draw legal threat over media players
By CaptainVideo in forum ComputerReplies: 8Last Post: 27th May 2007, 15:53
