Hi,
I Need To Know What Programs Are Best For DVD To DVDR,Do You Have To Convert To VCD Mpeg 1 Or 2 First? Then Import It Into My DVD (DVDit) I Have A Pioneer 103 DVD Writer And I Use TMPEG 2.5+ Daily To Rip DVDs To VCD Mpeg 1 But Am Getting Bored with 2 Discs And The Quality,I d Rather Have DVD,Please Give Us Some Simple English And Not Science How To Do It,
Thanks.
Results 1 to 15 of 15
Heres the guides http://www.vcdhelp.com/forum/viewtopic.php?t=109346.... I have been using also I hear DVD2DVDR is a good program. I am just about to try it. Also if you are willing to spend money DVDXCopy is out. It is an awesome program except the disclaimer it leaves on your dvd copy, but there is a tutorial out that tells how to get rid of that. Rencoding is really all up to. It depends on how big the original DVD is and what features you want to keep with your movie.
DVDXCopy is a joke all it is a bunch of freeware tools packaged together. its amazing all the suckers out there who bought that garbage. plus with a little bit of searching you can get it for free. as far as programs you need are DVD2AVI, DVD Decrypter, IfoEdit, Nero - Burning Rom ,and TMPGEnc.
I don't particularily like the program myself but you don't know what you're talking about and are just plain wrong, it is not a bunch of bundled freeware, the old one was (DVD Copy Plus or whatever) but this one is not. As for getting it for free you are telling him to Warez or Pirate the program, the developers are not giving it away for free??DVDXCopy is a joke all it is a bunch of freeware tools packaged together
I use it for 1 specific situation where I want to make perfect copies of a big movie that ends up spanning 2 DVD-R and where I want my own custom menus. I let DVDXCopy rip to my HD, then I Smartrip out the .m2v and .ac3 files to use into Maestro, works quite well. I've tried about 3 other ways including IFOEdit and ripping selected chapters in DVD Decrypter but sometimes get audio sync problems yet DVDxCopy gives me good audio sync. All other times (95% of the time) I use DVD Decrypter, IFOEdit, ChapterExtractor, Smartruppier, Maestro ...etc.
rhuala -
In this forum go to: DVD RIP. Then look for DVD 2 DVDR for Dummies (sorry about the title). It has all you need and it works!
i have tried this program and seen how it works and it dose the samething as freeware tools can do. the dude who made ifoedit also is one of the people who helped make dvdxcopy. how much is ifoedit? its free. well this program has some good points. if you are to lazy to learn how to copy dvds. then this is the program for you and if you like throwing money down the craper this is the program for you. well if you don't know how to read then this is a pretty good program for you. this is how i look at it i am not going to pay for something if i can get for free. so i guess you don't download mp3s? because its the same thing.
No it doesn't! It does not cover a 2 Layer DVD9>4.3GB to DVD-R without re-encoding (loss of quality). If you use this guide on a DVD like Abyss which is some 170min long you will have to re-encode with a very low bitrate ~ 3100 and will drop the quality considerably as mentioned above.In this forum go to: DVD RIP. Then look for DVD 2 DVDR for Dummies (sorry about the title). It has all you need and it works!
If you want to back up a movie like this you need to parse two DVD-R's to maintain perfect quality! There are 2 guides for this I've tried but as I mentioned above I've ran into audio sync issues with both:
http://www.fukrulez.com/modules.php?name=Content&pa=showpage&pid=12&page=1
http://www.doom9.org/ (Guides -> Split a DVD to 2 DVD-Rs)
Also, the guide u recommended would be a horrible choice for a DVD5 disc or a DVD9 that could be ripped to less than 4.3GB. It would take 3 times as long and drop the quality.It has all you need and it works
