  1. I'm thinking about buying a DVD writer to double as a video-disc-recorder and a data backup for my 'puter. Been reading a Computer Shopper article which tells me: "the life expectancy of the DVD+RW media is up to 1,000 times that of the DVD-RAM media."
    As far as I can find out, DVD+RWs are rewritable about 1,000 times and have a shelf life of about 100 years ; whereas DVD-RAM discs are rewritable about 100,000 times, and have a shelf life of 30-100 years.
    Is there some other factor I'm missing, or is the Comp. Shopper quote just plain wrong?
    Cheers -
    g k
  2. 1000 times longer than DVD-RAM???
    So if DVD-RAM is 10years a DVD+RW is 10'000 years.
    I do not think so, and even it is you would not find a drive
    that could read your DVD+RW in 10 thousand years from now.
    DVD+R and DVD-R last longer than DVD+RW/-RW
    so use that type of media.
    If you choose DVD-RAM just becuase you can write to it 100'000
    you need to get your head checked out.
    Who would use the same disc and write
    to it once a day for 273 years?????
  3. >Who would use the same disc and write
    heh.. a geek Time Lord
    No, you're right, that's what I reckoned - but the rest of the article seemed to make sense, so I wondered if they were maybe saying the DVD-RAM discs were less reliable or something...
    g k
