I'm a newbie and haven't even learned all the terms yet, but I want a TV tuner/capture card (cable TV in) that I can then make VCD's or mpeg files with. What can I get that will give me high quality results and is relatively trouble-free? My system is 1.2Ghz Athlon/ASUS A7V133/Leadtek GForce2Pro 32MB/ 512MB RAM/ 40GB IBM 7200rpm HD. I don't have firewire capabilities right now.
Spend the minimum you need and get a Hauppage WinTV GO for < $50 USD. You'll capture in AVI and then convert to MPEG afterwards. You have such a fast system that this won't be too much of a problem. Spend more later (if you'd even want to) once you know more about digital video.
you have the system power to go for a real time mpeg encoder.
try an ati all in wonder raiden.
i have an ati all in wonder n it works really good. it can't do mpeg capture though. even though it has something called 'mpeg raw'
i have a 350 p2 and i can capture in ati vcr 2.0 just fine.
Using S-Video To Capture Into Hauppauge 1600 TV Tuner Card
By waldodiodio in forum Capturing and VCRReplies: 4Last Post: 1st Nov 2010, 18:49 -
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 18:46 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 10:52 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
