  1. I asked before if a 4.4 gig VCD could be created in a DVD. Some people said yes, however the programs that I use, Nero, VCDEasy, MYDVD/HP version, and ULead do not seem to agree with the above premise.
    Does anyone know the mechanics of doing this - THE HOW TO SECTION DOES NOT SPELL IT OUT - or I have not been able to find it.
    I am having other problems when trying to create DVDs:
    1.- If I use MYDVD/HP version, when I load a 1.67 gig file it is then converted to the DVD format and comes out at about 7.4 gig. This program then says that the file is too big. I am loading roughly 2 hours and 41 minutes of mpg video.
    2.- If I use ULead Movie Factory, I try to load MPG files and I get a message that the MPG files are not compliant with DVD standards. OK, so I convert them using ULead's Video Editor. Movie Factory still says that the files are non-compliant. For DVDs I look at the ULead table of MPG compliant file systems and I find that mine fall into one of the categories. What gives?
    Any help will be appreciated. Thank you.
    cai
  2. If you use Ulead DVD Workshop you can load each mpeg clip as a chapter point and encode to SVCD to a DVD-r
    entirely TOO much time on my hands
    www.easydvdcopy.net
