Hi all.
Backupping a DVD that looks fine on TV but completely "slashed/sliced" (interlace) on the computer monitor. Thing is, after encoding it to SVCD, it looks that bad on the TV aswell!?
Tried the following settings on ffmpegx, all to no avail:
Deinterlace before encoding CHECKED + Not interlaced
Deinterlace before encoding CHECKED + Frame
Deinterlace before encoding CHECKED + Field
Deinterlace before encoding UNCHECKED + Not interlaced
Deinterlace before encoding UNCHECKED + Frame
Deinterlace before encoding UNCHECKED + Field
Running out of ideas, and feeling very desperate in backing this one up (expensive Import disc I really don't want to be without)
Thankful forany input,
/Wizeman
"I have not failed. I have only learned what does not work."
-Edison
I am having the some problem, copying to DVD-R. I think the only solution might be swapping fields. MPEG2 video for TV should be Upper Field First, but many sources have Bottom Field First as interlace method. You should swap mode to upper field first, but I haven't yet been able to get good results. You can try... let me know then!
Bye
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
Just get rid of interlace problems, no good quality expected
By TheOtherSwede in forum Video ConversionReplies: 8Last Post: 13th May 2009, 15:16 -
Why am I getting crappy DVD encoding? (interlace problems, etc)
By timmus in forum Authoring (DVD)Replies: 15Last Post: 14th Apr 2008, 10:23 -
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 21:46 -
ffmpegx Problems! Help!
By The Sumerian in forum ffmpegX general discussionReplies: 4Last Post: 10th May 2007, 01:36
