Good Morning All,
This should be real easy.
All I am doing is capturing using PowerVCR and my Winfast 2000XP and trying to Author/Burn using my DVR-104
Specs on capture:
720x480, Mpeg2, 5000CBR, 224/48000 Audio (Mpeg is fine all the way thru)
I have tried Tmpgenc to demultiplex and IFoedit to make the folders and also
DVD MF (with patches), but I am off about 3 seconds at the end of a 60 minutes show in audio. DVD MF says it is multiplexing my file..I assume it is not reencoding...Took about 45 minutes from start to end of burn for a 60 minute TV show.
My capture drive is a 5400rpm and that is the demultiplex drive also..should not be a problem I would think
I am going to try DVD Workshop, but my hopes are not high
Is there anyway to verify my problem with other tools???
thx
Mark
(avstodvd) Converting m2ts to dvd...sudden sync probs.
By newbtube in forum Video ConversionReplies: 17Last Post: 2nd Apr 2011, 23:27 -
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 06:35
