Hello.
I have are problem can somebody help me whit that.
I want to burn svcd whit nero,mp3,mp3pro,wma.svcd plugin but i can only burnit as vcd,i have delete maney thimes nero and install differend versions but the same problem.
Example:i have are mpeg movie [svcd] and i start nero menu compile a new cd,Other cd format's,you have nowe the cd menu 1audio,2vcd.when i klick vcd nero whil encode the movie but i can't not playing that movie.
Greetings
Below are comments someone else posted regardng this problem. Hope this helps
you need to select the SVCD in nero.
you selected VCD by mistake.
you must have been using the nero wizzard.
i think the wizzard only lets you select VCD.
turn off the wizzard in nero , do it by pressing "help" and
unselect the "use the nero wizzard".
now press "file" and "new"
and select from the left side - svcd.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
