Well, I am stuck.
I was following Virtual Dub capture step by step
http://www.vcdhelp.com/mjpeg.htm
and everything was working fine until I selected 24 bit RGB under Video> Format(IMAGE FORMAT).
When I selected that and hit Okay, I got a black screen with one green line going across the top of the monitor.
Everytime it happens, I have to reboot. The audio is still going on but you can't exit the program or see anything on the screen.
Image Dimensions settings are
352 X 240
Huffy and PicVideo codecs are installed.
Now when I go to "Launch VirtualDub and select File->Capture AVI", it goes right back to the black screen causing me to have to reboot again.
I am Using VirtualDub-1_4_10 but I also tried with version 1.3 and got the same problem.
How can I change it the Image Format back to YUY2?
I have been trying to find that answer for the past 3 hours but to no avail.
any help would be great.
Skydogj
http://www.phishhook.com/lists/skydogj
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
Vdub: Screen Capture
By dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 17:24 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
VDub captures in black and white. NO color. SOLVED BUT NO AUDIO NOW
By bradyfan123 in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 21:04 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
