Hey all !!!
If I have a DivX movie and want to convert it (XS)VCD. How do I know which bitrate that gives the maximum quality withot using to much?
Is there a point of using SVCD bitrates if the original quality of the movie isnīt that great.??
if the source is bad the would the higer bitrates only be used to calculate "noise"..... Or???
Can you calculate the maximum needed bitrate (to keep original quality) using the info from the orignal avi (frames size or somethin???)
Doohan99
Results 1 to 1 of 1
avi -> mpeg1 in high quality
By steve1401 in forum ffmpegX general discussionReplies: 5Last Post: 6th Nov 2009, 20:53 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 11:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11
