Some dvix files is sometimes corrupted in a setan place in the movie. That makes windows media player to lock on that screen but the audio continious as usual. VirtualDub and TmpGenc craches/locks when reacing that point in the movie.
What can be done to correct the errors inthemovie???
/Tompa
try downloading the video again or from a different mirror. if that doesnt work try using different dvix drivers
There is no mirrors.
The file is just corrupt.
Isn't it any software that can repaire a dvix file?
/Tomas -
There is a prog called divxfix, that will strip and rebuild the divx file so that you can play it on the pc, although if you want to transcode it to vcd /svcd it'll probably look awful with corrupt sections. There is also a registry fix called antifreeze that'll allow your divx to play without locking up......I'm sure you cand find them by searching the formu
Nikon Coolpix corrupted .mov video file repair
By darrenpj in forum Video ConversionReplies: 3Last Post: 31st Mar 2012, 17:15 -
Any way to repair mp4 corrupted in transfer from Android to PC
By smashmashups in forum EditingReplies: 5Last Post: 21st Oct 2011, 16:10 -
Repair corrupted mp4 (no moov box error)
By kkelis_ in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2011, 02:44 -
repair corrupted 3gp files that has been undeleted.
By dodotiti in forum Newbie / General discussionsReplies: 4Last Post: 15th Sep 2009, 00:15 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 08:54
