Hello
So I've searched this forum but I did not get my solution, hope someone could help
So I'm frameserving an avi in vdub to cce, I use full process mode audio with resampling to 44.1kHZ ( someone wrote this might be the problem)
Anyway I dont encode audio with cce.
I joined to separate avi files ( part 1, part 2 and I'm creating 3 discs)
This couldn't be the problem could it?
I use 2 audios at 384 kbps total, so the max bitrate is 2336, min is 1000 average is 2000 ( 39 minutes), I use 2 pass VBR.
When cce creates its own little vaf file it prompts disc write error....
Then it continues to encode, it usually prompts that has a problem, and ends up with a bunch of crap Megs of .mpv on my disc.
I tried scanning the stream, reinstalling the vdub handler, reinstalling cce, ( No the system is fine!!!!!!!!)
Yeah I've read about free space problems, but I couldn't figure out what is with free space I have 5 G's free.
Anyway I save the 2 passes under one file
PLS help! I want to watch my starwars svcd under the xmastree!!![]()
Results 1 to 1 of 1
Write Error with Internal DVD Writer
By Soviani in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Oct 2009, 00:50 -
Write error problem with mpeg streamclip
By mattcourage in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Nov 2008, 10:57 -
Can a 4x burner write to a 16x disc?
By bobarnett in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Sep 2008, 15:47 -
write 2 movies in 1 disc
By akakiami in forum DVD RippingReplies: 6Last Post: 10th Sep 2008, 07:06 -
Pioneer 420H - Can't Write Data Error
By cie3 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 23rd May 2007, 22:51
