hi from new member, i just burned my first vcd using averdvd ezmaker, with neodvdstandard, ok, changed vhs to mpeg-1 file with no problem. when i tryed to make a vcd from mpeg-1 it burned with no problem. when i tryed to play it, i found out that it's 5 folders on the cdr. is this right they are file type DAT. is this the correct format for vcd's? if not how do i convert the dat or 5 folders to the correct format for vcd's? its this correct to assume that 5 folders on cd are video. thanks for any INPUT.
Yes you did everything correctly. If you look in the mpegav folder there will be a dat file for each video track you created. You can open these in windows media player if you wish or you can load the disk in a software or hardware vcd/dvd player.
No MOV thumbnails in XP folders?
By terrypin in forum Newbie / General discussionsReplies: 13Last Post: 30th May 2011, 14:08 -
Folders changed into 32 kb files, help!!
By caesarhawy in forum ComputerReplies: 1Last Post: 27th Apr 2011, 14:57 -
exact copy with more than 2 folders ?
By takenotes in forum MacReplies: 3Last Post: 27th Oct 2010, 21:19 -
Windows XP problem with folders
By jyeh74 in forum ComputerReplies: 1Last Post: 20th May 2008, 17:33 -
Folders keep shutting down?
By aelfheah in forum Newbie / General discussionsReplies: 12Last Post: 26th Feb 2008, 15:07
