Problem:
I have about 20 .AVI files, and only 2 of them play with video and audio, while the others only play video. When i open one of the buggered ones, windows media player (6.4) 'Attemps to download codec from website'.. After it has downloaded, there is this thing that says: Do you wish to install and run Windows Media Audio codec? i click yes and then the player says A decompressor was downloaded for this file, but it didn't work. You may need to restart your player or browser. Here is the error code thing that WMP comes up with:
And then the AVI plays the video without the sound.Unable to download an appropriate decompressor. (Error=80040200)
A decompressor was downloaded for this file, but it didn't work. You may need to restart your player or browser. (Error=80040200)
Answer:
I dont know....... Is there an audio codec pack that has like 5000000 codecs that i can install, and mabe the right one is there?? I know It can work as i could play it on my other computer (before it crashed and i had to reinstall windows).
The website it tries to get it off is
http://codecs.microsoft.com/codecs/i386/msaudio.cab
-mitch
Is your Nimo Codecs loaded? If not, check the Tools section.
Hello.
So how the hell did they do this??!!
By Chilla1142 in forum EditingReplies: 9Last Post: 1st Jun 2011, 10:46 -
ffmpeg is hell...
By nmaxwell in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2010, 04:47 -
vp6 hell
By Mark69 in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 21:37 -
What the hell are these files?
By lordhutt in forum ComputerReplies: 8Last Post: 25th Jul 2008, 13:48 -
The toolbar hell
By Midzuki in forum Off topicReplies: 6Last Post: 24th Aug 2007, 14:19
