Gday all.
Is it possible to convert frame rates because I have a movie with 23.967 frames per second which is NTSC, and to watch it on my PAL TV I need to be able to convert it.
When I burn it to VCD in the NTSC version. It is extremely jumpy and I can't watch it.
If anyone has any alternatives, that would also help please tell me!
Thankz
Cazza
What happens when you put it into TMPGEnc, select a PAL template, and try to convert it to a PAL MPEG file that way?
Hello. -
When I try to convert it in TMPG into PAL, it stutters a lot and the quality gets worse. Are there any ways around this?
Cazza -
The source is 23.97 Progressive (I take that it is)
Should not be hard to convert to 25 frames (50 fields interlaced)
I have never seen a 24:1 Pulldown option in TMPGENC though.
The way PAL TV stations do it, is that they play back the 23.97 source at
25 frames/seconds and increace the audio speed by 4%.
In USA they spread 24 frames over 60fields (3:2 pulldown)
and is called telecine (the DVD player do it during playback)
Read about changing audio pitch here:
http://www.vcdhelp.com/forum/userguides/78178.php
I wounder if that makes American sounds like they talk like girls?
a 4% change should affect the audio a little i think..................
Maybe PAL countries never really heard Stalones real darker voice?
