I'm trying to convert an avi divx movie to mpg with tmpgenc, but a "Stream Writing Error" message comes up at the same place (a few seconds from the start) in the movie every time. This has only happened with this specific movie and at that specific time. Is there any way I could cut the avi to get rid of the "bad" section that causes tmpgenc to crash? Should I try seperating the audio and video?
There are a few AVI's with bad frames, and TMPGEnc will give that error. There maybe others further along the movie, so even if you cut out that part at the beginning TMPGEnc might give the same problem further along the movie.
I use "vdub-mp3-freeze.exe" it scans the movie and creates a list of bad frames. You can then use Vdub to remove those bad frames (At the nearest keyframe)
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 08:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 17:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 11:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 18:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 08:28
