Photo2VCD Professional is an easy to use DVD/SVCD/VCD authoring application. This tool can help you to easily burn your favorite digital photos into a DVD/SVCD/VCD compatible slideshows video CD (VCD or SVCD) with background music and transition effects(http://www.photo2vcd.com).
1. Launch Photo2VCD Professional
2. Add/Del/Rename album. This function help you to burn multi-albums on the same disc and navigate to the one you want to play by your remote control.
3. Click on Add Photo to add your digital photos. The format of photo file can be JPG, GIF, PNG or BMP etc.
4. Click on Edit Photo to edit currently selected photo with a powerful photo editor tool.
5. Click the button of Add Music… on the Background music tab to add background music file for current album. The format of background music file can be MP3 or WAV.
6. On the transition tab you can set the transition effect options for current album.
7. You can also set the transition effect style, photo delay and subtitle for an individual photo.
8. Click on the Preview button on the toolbar to preview the final photo video before you continue to burn it into a video CD.
9. Click the Burn CD button on the toolbar to open the CD burning dialog. Follow the burning wizard, you can easily burn your digital photo album into a great video CD so that you can play it on your standalone DVD/SVCD/VCD player now.
10. Done.
Closed Thread
Results 1 to 15 of 15
I would not suggest you make a photo album this way. It converts the high resolution images to low quality, low resolution mpeg-1 video just so you can have transition effects and music.
Use Nero, select the VCD template and drag all your jpg photos over and burn. You get high quality, high resolutions stills on your TV from your DVD player.
WinOnCD PE has a great option to automatically fit the number of slides to the length of the selected background music. This feature eliminate the need to spend time adjusting the number of photos and transition interval to spread over the music, as the intervals we may choose are in 1 seconds intervals, and we are unable to select half-seconds or even 0.1 (for example 4.5 or 5.5 seconds etc).
This is true for DVD Pictureshow and PictureToTv. I dun think diz new Photo2VCD is going to be any different huh...?
Thks.
Just tested the standard trial version. This is my comment:
(1) The video quality of DVD format MPG2 720x480 is horrible
Comment: do not release a video software for money before really knowing MPG2, since no body here is stupid.
(2) Can not set the image display time to fit the background music
Comment: do not release a software before knowing what the software should be.
(3) Nothing (expect there is a DVD MPG2 option) is better than PictureToTV, which I personally think is very good to creat a VCD picture show with fancy trasitions.
Comment: do not release a software before knowing your competitors' product.
Final comment: do not release a software like this.
What are your comments on this tobee
I am not any software developer at all. I am a mechanical engineer who likes to make home video and home photo (S)VCDs. And I am also a nice person to tell the truth to the people. I hate the guy who tried to mislead the readers, so this why I stood up here.
Originally Posted by tobee
Converting 5.2gb .mkv video to DVD5 using Any Video Converter Professional
By supersi in forum Video ConversionReplies: 1Last Post: 10th Dec 2011, 02:06 -
What is the best professional video editing software for PC (2010)?
By exillion in forum EditingReplies: 18Last Post: 15th Jun 2010, 23:04 -
Buying a professional or semi-professional camcorder
By besimky in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2010, 16:21 -
create menu for DVDs usin photo shop
By hellbound in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 04:34 -
How to become a professional video encoder.
By Alex DeLarge in forum Newbie / General discussionsReplies: 7Last Post: 25th Sep 2007, 20:59
