Hi,
While using TMPGenc the CPU usage is nearly 100% (P4 1.8G MHZ, Win2k). Is this normal ? is it bad for the computer ?
Thanks !
Sade
depends on your priority settings...if you set it to low, it's gonna use less CPU, but obviously take longer time to encode...
if it's 100% CPU usage, you prolly set priority to high -
Actually, it will be 100% no matter the priority, that just determines if TMPGEnc get's priority over other tasks. Thus if you were working on other things at the same time, TMPGEnc will finish faster if it's set to high priority than if set to normal or idle but still probably not as fast as if you weren't doing anything regardless of the setting.
The CPU is doing the work to encode. So if you want something to be encoded, the CPU will be used. And since you want it NOW the CPU just works as fast as it can, hence the 100% usage.
The only problem with running at 100% CPU usage for a long time is if you overclocked your CPU (and you'd know if you did this) and it overheats. Otherwise any properly designed computer can run at 100% CPU for days.
Actually, if you're not running at 100% CPU while encoding video there's something wrong - you've got another bottleneck in your computer like a slow hard drive or low ram.
What do i need if CPU usage goes 100% when video editing?
By NaHLiJ in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2013, 20:13 -
MPEG Streamclip issues - 100% CPU usage, unusable...
By semmel in forum Video ConversionReplies: 6Last Post: 27th Dec 2009, 18:27 -
HD playback suddenly broken - 100% cpu usage
By mr-scarface in forum Software PlayingReplies: 11Last Post: 16th Apr 2009, 16:12 -
100% CPU Usage while outputing from TMPGEnc DVD Author
By lj01 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2008, 11:09 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 10:59
