I am having some major problems. I have an avi file that I am trying to cut into 2 parts, using VirtualDub. I have done this successfully before, but with this avi I am getting an error message about VBR when I open my avi in VirtualDub. I researched it a bit, and from what I understand, I should save the audio as a wav file, and then use TMPGEnc to put the video and audio together, which makes a mpg file. I have done this, and I even cut the mpg into 2 parts with TMPGEnc. But when I try to burn the mpg to VCD format using Nero, I get an error message from Nero saying my mpg file is invalid. It says the following problems were found:
- Stream encoding which is invalid for a (Super) Video CD
- Invalid video stream: 23.976 frames/second, 640x272 pixels
I have tried turning off the standard compliance and continuing to burn to VCD, but it does not turn out at all.
So, here is my question:
Is there some step in the editing process that I am missing, or possibly doing wrong? Is there any other program that will NOT give me a VBR error that I can use to cut my avi into 2 parts? I am going crazy trying to figure this out!
Any help would be GREATLY appreciated.
Thanks....
PS-Please post response here, don't email, because I won't receive it.
Are you using the template, or the Wizaqrd? If you wish to make an SVCD file, the TMPGEnc templates makes the video SVCD compliant.
Hello.
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 11:36 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Windows Color Profiles ignored by TMPGenc, VirtualDub, etc. ?
By sanlyn in forum Video ConversionReplies: 13Last Post: 28th Jun 2008, 09:42 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
