I'm getting an error: 80041c21 while trying to burn a DVD from Ulead DVD Workshop 1.3. I'm using CVD compliant streams and have 2 menus with motion buttons.
I have "do not convert compliant files" checked on, but even if I uncheck it I get the same error. Ulead support haven't responded to my emails yet...
Anyone else experienced the same thing?
Yes have the same problem here.
I used the "replace audio" function and loaded a m2v for video and a 48 kHz wav for for the audio.
Strange because it is saying it has a problem with audio conversion, but I want it to record it to dvd in PCM so no conversion should be neccesary... -
Mmmmm, there's something wrong with my installation obviously. I re-installed Ulead DVD Workshop and patched it to 1.3 on a CLEAN and NEW Win XP installation on a seperate HD and now it works fine. Obviously something in my "normal" XP installation messing things up......maybe some old dll's or drivers or.... ???
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 09:25 -
DVD Workshop 2 audio problem
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Feb 2008, 19:49 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
