  1. Is there program that will re-encode all the VOBs so the movie will fit on one disk?
    If not, how do I figure out what to set the bitrate at? Want the best quality I can fit on one disk.
    PA, USA
    If you wanna do it manually.. i found that the calc here..
    http://pwp.netcabo.pt/0165394101/TMPGEnc_Calculator.html
    from this website
    http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html'
    is pretty helpful, and accurate
  3. Wow - Thank you for that johneboy! Very hand little tool.
