I just got Goldmember downloaded and it plays fine on my computer. When i go to encode it with TMPGEnc, it has problems. I stripped the audio with v-dub but when i encode it, there is no video. I tried saving the file as avi(audio and video) with V-dub and i get file unsupported. Anyone else having the same problem?????![]()
Why would you download that?why? to reencode it?
whats the point? rent the dvd... -
The file is probably needs the XVID codec to render the video. Try installing the xvid codec from the nimo codec pack and see if that makes a difference. Do a search through all the forums on xvid problems and that should help solve any further problems.
