i recently downloaded a music video from the internet, put it onto a cdr using nero 5.5, VCD. but it only plays for about a minute when i put it into my standalone player then freezes (the original file was an avi 352x288)...why???? i am using a philips dvd 633 player which SHOULD play all media types!!! can anyone help me?
Here is compatability reports on your player:
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=1260&Search=Search&#comments
The first thing you should know is....do NOT use Nero to encode (its ok for authoring though).
I would suggest using TMPGE to encode.
I would also download this version of Virtualdub and scan the video for bad frames.(scroll down to the "MP3_Freeze" version)
http://www.digital-digest.com/dvd/downloads/virtualdub.html
If you have bad frames (and the amount is not more than a couple of hundred)you can remove the frames with Virtualdub,then re-stream the AVI ready to be encoded."Today is only yesterdays tomorrow"
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 15:13 -
more than 120 minutes on 1 DVD
By icethekicker in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2011, 17:32 -
20 minutes to burn a DVD!
By persephone in forum DVD & Blu-ray WritersReplies: 22Last Post: 9th Dec 2010, 15:12 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 23:43
