Simple question, but I hear constantly conflicting answers:
Can this card do stereo from the tuner or not? I want to capture stereo audio when using the TV Tuner in whatever format. Will it let me?
I hear you have to connect it to the line in on the soundcard to get stereo sound... which is TOTALLY fine for just when I'm viewing. But it's RECORDING stereo that I am concerned about - because I want to burn to VCD.
Thanks.
hi m8 i have the delux version of the card and i can get stereo from the line input i use that for all the inputs i use it on the svideo / tuner and composit hope this help so you m8
It depends on which Leadtek Winfast TV2000 version you've got. If the MTS option is marked on the retail-box, you can view and capture TV in stereo. Otherwise it's mono.
If you connect a stereo-VCR or something else to the line-in you get stereo. But this has nothing to do with the tuner-card.
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
