  1. I'm now convertion Avi to Svcd, but how long will this take (on a Pentium4, 2 Gherz, 526 Ram). I'm now looking at a Dos-screen, were I see a lot of "Not scaled properly". What the heck does that mean?
    TNX,
    Dweomir
  2. Don't you mean how long is a piece of string?
    Really it depends on so many things. You gave your PC specs which is a good start but encoding time also depends on length of movie, encoder used, settings or filters applied etc, etc. Can't really help you without more info.
    FYI, using Tmpgenc on a 2.2Ghz P4 with 512Mb ram and divx source. I encode a 2 hour movie to DVD format using 2-pass VBR and High quality but no extra filters in approx 12 hours. SVCD encodes would be about half that.
  3. Originally Posted by bugster
    12hours????????
    I just got an XP2100+, did my first test last night..and encoding from Divx to DVD with CCE was 3x realtime...(30 min for 1:30 min movie)
    I would have thought a P4 would have been much faster than that
  4. medievil wrote:
    12hours????????
    CCE is MUCH faster than TmpGenc but still to get that kind of performance you must have been using CBR or at best 1-pass VBR. That will not produce as good a quality as a 2-pass TmpGenc encode. It is commonly accepted or at least considered by many the Tmpgenc 2-pass VBR is closest to CCE 3-pass VBR in terms of quality, given the same source of course. In that case CCE is probably only about 10% faster than TmpGenc. As I said, I do use the high quality setting. Using fastest settings is more than twice as quick but as I usually encode overnight I am happy to sacrifice speed for quality!
  5. It was VBR 1 pass...
    mind you it was just a test, but mostly if I was going to go from divx to DVD, then VBR 1 pass is enough...Divx is lossy to begin with and you're not going to notice any difference from the original Divx at DVD bitrates. My min and max in CCE are always 0k and 9800k
